weird problem with lilliput durring bootup (with pic)
  • weird problem with lilliput durring bootup (with pic)
    i had my lilliput TS for about a week now from the ebay guy, it worked fairly well for the 1st few days, now durring boot up this is what happens http://mywebpages.comcast.net/djrkd/carpc/weird.jpg once the computer is in windows its fine, but durring the bios it flickers like crazy. does anyone know what can be causing this?
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
    Mine does the same
    Mine does the same...the vga lcd doesn't seem to like low resolution images
      What might have happened (as I found during many hours of trying various resolutions out - see other thread on here ) that the screen only holds so many timings settings and that it may well have lost those for the 80x25 text screen used during bootup.
      Try hitting the < key on the front of the Lilliput screen as soon as the boot screen appears as this will autofocus the lilliput (and I might add this seems to be one of the best monitors I have had for getting the image edge to edge and centred on its own) It might even be better if you hold down del key to keep it on this resolution as the bios setup uses the same screen.
      HTH
      My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
