Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ?
  • Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ?
    I've searched and emailed Armen but haven't had the answer yet.
    Has anyone managed to fit a DigitalWW 7" touch panel into the Lilliput VGA screen ?
    The touch panel on my 7" Lilliput VGA cracked - the screen dropped from my dash onto the gear shift when the self-adhesive on the swivel mount gave way . The good news is that the LCD screen itself is still working. The touch panel must have absorbed the impact and saved the LCD screen.
    I am looking at DigitalWW's 7" touch panel as a replacement. It's a 4-wire resistive panel just like the one in the Lilliput. The USB controller in the Lilliput looks like the same one sold by DigitalWW. The only difference that I can tell is the width of DigitalWW's panel is 169.5mm whereas the cracked panel's width is 165mm. I believe that the Lilliput housing can accomodate the 4.5mm difference.
    TIA
    S H Chua
    I just emailed you
    Armen
    TIA
    S H Chua
    http://www.digitalww.com
      Originally posted by digitalww
      I just emailed you
      Armen
      Thanks, Armen. Can't wait to get my screen working again
