Datalux 3.3v - 5v converter
  • Datalux 3.3v - 5v converter
    I need one of these for my LMV10R so I can use it with my m10000. I know that they can be built, but that's a little outside of my capabilities at this point.
    I have seen prebuilt units on ebay before and somewhere else, but can't find them now. Anyone help me out with a link??
    Thanks,
    Brodee
    1992 525iM - 1989 325is - 1993 525iT
    7.4" Lilliput w/touch, M10000. GPS, TV, DVD, WiFi.
    Thanks,
    Brodee
    It is very simple and cheap to do your own modification. It will only cost about $10.00. Otherwise you can get one from the datalux site for about $100.00 or more.
      If it involves soldering then I'm out of luck :-( I thought someone was selling these on here??
        It's starting to frustrate me. I have 2 of these monitors, one is an LMV10R2 which uses the microtouch touch controller and works fine at 5v plugged into my epia. Only problem is the touch doesn't work, tried everything and can't get it to work. Soooo, I bought another one, this time an LMV10R. This one works great, touch works, everything is peachy except it won't work on my Epia :-(
        Thought about taking the lcd and vga controller out of the R2 and putting it in the case of the R so that I could have that working touch, but the touch connects differently and isn't compatible.
        Maybe I should just buy a 10.4" usb touch overlay and put it in the R2??
