TM-701L is it touchscreen?
  • TM-701L is it touchscreen?
    Is that monitor a touchscreen ?
    If not, should I get that one with TSK Installed from digitalww.com for $360, or get a liliut from them $350 ?
    Which one is better ?
    Touchscreen Kit, when its installed, does it look stupid ? Is it noticable ? Some take a pic please. I want to get a good monitor, so please help me out. Thanks,
    Milos
    nevermind, its not a VGA monitor...sorry.
    just tell me what monitor to get.
      "TruckPC -- All done baby!
      by: mantis 8-8-2003
      Descripton: 99 GMC Sierra Ext Cab Santa Fe Conversion. -- Touchscreen 7" TM-701L, Epia M10000, 512 Megs ram, 80gb 7200 ata133 maxtor "
      http://www.mediaengine.org/index.php...ults=5&start=1
      fourth monitor down..it says its tm-701L and its a touchscreen, and hes running some kind of a pc programs...i thout 701L isnt a VGA ?? please explain!! thanks
        TM-701L + TSK monitor doesn't have VGA inputs so you need to use a Video card which has TV OUT. You can use this monitor with a computer but text is not going to be as crisp as on a VGA LCD. When viewing a video or using a Front End like Media Engine or Media Car it looks perfect. The programs I just mentioned use larger text and bigger buttons so navigation them with touch screen is very easy. However you will have to work on getting the picture perfectly aligned on monitor and this might be a little difficult (you might have to use a program like “PowerStrip”). If you do a search on "TM-701L" in this forum you will find lots of topics that will cover everything about this monitor, how to use it with your computer, etc…
        If you just want to connect your monitor and touch screen and not worry about your screen not aligning, etc... Then you might want to go for the Lilliput. All you have to do is connect it to your computer and enjoy.
        by: mantis 8-8-2003
        http://www.digitalww.com
