Do I need a VGA display?
  • Do I need a VGA display?
    I got an old laptop off ebay to power my car pc but i'm pretty sure it only outputs in VGA (the manual didn't list any NSTC/PAL compatibility). Would I have to get a VGA display to use with this laptop or can I just get a wire that converts VGA to RCA video(red/white/yellow - the yellow one)? The wires are pretty cheap but I don't want to waste $15 to get a wire just to test it and find out it doesn't work.
    depends on what you want to run on your setup
    '98 Explorer Sport
    80% done
      I mean will it actually WORK? Will an LCD screen meant for component video pick up a VGA signal properly?
      Gonna be running media engine.
        you would need a scan converter, and those things arent $15
        Debt as of 1/1/05: $34,354.48
        Debt as of July 4, 2007: $0.00 explanation
        I'M DEBT FREE!!
        I'm now a reasonably successful gunblogger.
          Yep, they are more like 100. The extra cost of a scan converter to run a composite display isn't worth it. If you had a tv-out it would be a different story, but I think you should just go for a vga screen.
            like this?
            http://www.pccables.com/cgi-bin/orde...502&rsite=link
            Would it be worth me just getting a VGA panel instead?
            I'm hoping to go with an in-dash (not necessarily motorized) unit and I want to try to keep it <$450 w/ touch kit. I was looking at one at digitalww for $360 w/tsk installed which was in dash, but it's component. The vga version is $550 ish in dash w/tsk. Is a vga lcd panel really that much more?
