800x480 on my laptop vga output
  • 800x480 on my laptop vga output
    hi, i have been stuck all days messing with powerstrip to get the naive 800x480 resolution for my monitor. i have a gateway solo 3450 laptop with the s3 savage ix graphic card video chip.
    under powerstrip, the customize resolution option is blurred out, so i'm thinking that my graphic card does not support customization of resolution?
    i tried creating a monitor driver file with the 800x480 resolution and updated my monitor with that driver, but it still does not give the option to select the 800x480 resolution.
    would somebody please help?
    i agree
    My cars
      Are you just using the external monitor or are you using both? I have had problems when both screens were active. Videos couldn't be displayed on more than one screen, mediaplayer just showed a black frame on one of them.
      Otherwise you just might be out of luck. Powerstrip doesn't support all graphics card.
        My sony notebook using ATI video and I need to set the primary monitor as the external monitor. Then you can see video on the external monitor.
        I hope it would help
          yourbig
          I have the same problem with my EPIA M10000 using the onboard video. It appears that this (my) hardware cannot support custom resolutions. Perhaps you're in the same boat.
          MikeH
            Thanks noname, i figured that out myself. Just wanted to know if he ran dual monitors since that could be a problem for powerstrip to handle since they are on the same graphics card.
              from all indication is that i'm so out of luck. s3 graphic card dont support customize resolution. i cant set my external vga as primary display.
              so now im back to step one. build a mini-itx box, or get another laptop that supports 800x480 with powerstrip.
              my car is such a mess now. i'm driving everywhere with all my dash board out in the seats. (
              this is really a painful lesson.
                You absolutely have to have 800x480??? I run 800x600. I can't set up my external monitor as primary either, nor do I need to. It works fine just as if your laptop was docked. Close the lid and the laptop screen turns off, and the external output is on. ??
                Fabricator
                  Isnt 800x600 a little distorted on a 16:9 screen?
                    running the naive resolution of the lcd will always give you the best display quality. mine is running at 640x480 now, and it seems okay. but i will need to find a way to get a 800x480 signal to feed it some how.
                    it does seem like many laptop suport customization resolution. the wide screen laptop are too expensive. i hate to build a box because of the power supply issues.
                      Not noticeably.
                      Fabricator
                        Not noticeably.
                        Well it wasn't until you pointed it out!
                        Fabricator
                          Talking to yourself again Altimat ?
                          [H]4 Life
                          I'm a lesbian too.
                          I am for hire!
                            Yup going a little crazy with IRQL not less than or equal BSODs - maybe I should sleep....
                            Fabricator
                              DON'T EVER SAY THOSE WORDS AROUND ME AGAIN !
                              [H]4 Life
                              I'm a lesbian too.
                              I am for hire!
