best 16:9 resolution for xenarc 700tsv?
  • best 16:9 resolution for xenarc 700tsv?
    I just put a geforce4 in my epia m9000 so i could have good video and custom resolutions, set the thing to 848x480, and everything looks like crap, what would be a better resolution?
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
    Well...the actual resolution they are is 800x480...if you can get it to do that, then you'll be mustard
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
      I'll give that a shot.. you think i need powerstrip? or should the nvidia driver custom resolution tabe be able to deal w/that?
      Mods: Yep
        well, i tried it, but the text looks like *** and the screen isn't centered
        Mods: Yep
          Maybe because you're using a GeForce card. Try an ATI. You will convert rather quickly...
          Aura MR62 (F and R)
          My Current MP3s
          IamDefiler.com
            that's not what i wanted to hear
            Mods: Yep
              Russ, What generation is your Xenarc? Mine's is the first generation. It shows 848X480 perfectly. The second generation Xenarc that can display XGA will not display 848X480 properly. It looks like dog ****. I remembered my 2nd gen Xenarc displayed 1280X768 quite well. If you can get your video card to do 1024X600 that would be killer. My ATI AIW radeon DDR can do 1024X600 but I got rid of my 2nd gen xenarc so I couldnt test it out. I think the new controller that Xenarc put in cant handle wide screen format as well.
              NEW complete and updated My project with 100+ pics on 7-4-03
              If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
                i'm not 100% sure to tell you the truth.. any way to find out?
                I guess i should just mess around w/more resolutions...
                when i boot, i get a 640x3xx on the osd and it looks sharp, but then again, it's text based
                Mods: Yep
                  try to set refresh to 75Hz on 848x480
                  My nvidia and lilliput payed perfectly together with theese res/refr
                  '93 Opel Vectra A with Custom Dash with 7" lilliput
                  VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
                  http://zvi.home.ge/pics/?dir=vextra
                    hrm... i wonder if it's that it.. i've been tryin 60hz for a while...
                    what's the next step up from 848x480?
                    I want something that i can actually get to the bottom of property pages with
                    Mods: Yep
                      I run 800x600 on my Xenarc display, and it looks pretty good
                      If you're worried about things being out of proportion, then make/use a skin for your front end software that was designed to be used on a widescreen display, but has been modified to look great on an 800x600 display
                      Garry
                      www.aimee.cc
                        i'm running 800x600 right now, but would prefer to not have black bars for dvd's/divx movies
                        Mods: Yep
                          Depending on the software you're using, you can stretch it.
                          I know for sure that MediaCar can change the "zoom" level, so that it looks right when played back
                          Garry
                          www.aimee.cc
                            yes, but i have mediacar set to leave the area of my taskbar not part of the skin... blah... i just want a true widescreen resolution...
                            i think powerdvd5 no longer has the option to change resolutions to adapt to the picture size
                            Mods: Yep
                              If you can display higher than 480 lines of resolution then it's the 2nd generation. The next step up is 1024X600. It's the wide screen resolution for 800X600. If you can get your video card to do 1024X600 then everything will look proportioned.
