8.2 touchscreen VGA LCD for 15 USD~!?
  • 8.2 touchscreen VGA LCD for 15 USD~!?
    Here is the link
    Here is the description:
    Working CASIO 8.2" LCD Replacement for Laptop
    Part #: MD620TT00-01 CA51001
    Just add 12volts and a VGA Signal.
    This LCD was pulled from a working environment. No DOA Warranty.
    12volts, isnt that perfect for carputer projects?
    it take vga signal and has touchscreen!?
    for 15usd buy it now?
    now if someone can just find the pinouts...
    and btw, the seller never mentioned it was color...
    please post comments
    This is a laptop LCD, you will need a VGA controller to get it to work.
    www.earthlcd.com sells the required controller. If you look at their prices, you can see that the $15 LCD isn't really a bargain in the long run.
      Well they do day "just add a vga signal" which is not the signal that goes from the controller to the display (hence the need for the controller)
      either
      1) The seller has lied
      2) The seller has no idea
      3) The seller is telling the truth, but everyone suspects the above
        At $15, it would be worth it to take a pop, see if it does work fine with just a VGA signal
        If I was in the US, or that was for sale in the UK, i'd jump on it
        Garry
        Co-Developer of A.I.M.E.E
        www.aimee.cc
          Read the other threads on this. It is just a bare LCD screen No pin-outs, unless you want to pay $50 for one.
            either
            The answer is not #3.
              Another problem with the screen is that these appear to be the screen from a Fujitsu Stylistic 1200. If these are indeed the screens from the stylistcs they are not a touch screen that you can just use your finger on you might need the pen that came with the 1200's in order to do the on screen control, also the Stylistic 1200's are mostly DSTN (some were made with the TFT's).
