What video cards will do widescreen??
  • What video cards will do widescreen??
    Which cards have resolutions of 1024X600 or 848x480?? I've looked all over the net and can't find a darn thing.
    Thanks,
    Landon
    any radeon or geforce card will as long as you use powerstrip to make the custom resolutions
    '98 Explorer Sport
    80% done
      I have read a post by ZIN (?) that has used his desktop Geforce 2 card to get the 848X480.
      Good question though. I am interested in hearing more about it as well.
      1995 Mazda RX-7
      Custom 20B Conversion
        Will no card support these resolutions by default? Is there a tutorial somewhere for powerstrip?? It sounds easy but I know how those things can go sometimes. Thanks Guys, I just don't want to buy a card and then find out it won't work.
        Thanks,
        Landon
          I believe Tvtool might be able to help with this.
          P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
            Help!!
              The radeon 7000 upwards will support these without the need for powerstrip. Its just makes it easier that's all.
              http://www.dtvmax.com/radeon_guide.htm
              The bit about only genuine radeons working is rubbish as my 7000 sdr no-name brand worked no probs by changing the windows registry.
              My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
                SWEET!!! That's what I was lookin for. Thanks again!
                -Landon
                  So this one will work? http://www.dvcentury.com/Merchant2/m...de=96-230-9205
                  PAL/NTSC will work for the output to the Lilliput touchscreen tv right?
                  THanks,
                  Landon
                    I have nVidia GeForce2 MX200, Win2K, and driver form CD, 848x480 is an option in settings tab, my Lilliput shows great picture on this resoluton, but remember to set monitor vert. frequency to 75 Hz (on my Lily 60Hz looks crapy, 85Hz does not show anything).
                    but I need the same on M10K mobo :-((( I will brobably through it out (sell) and get some MictoATX with nVidia
                    '93 Opel Vectra A with Custom Dash with 7" lilliput
                    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
                    http://zvi.home.ge/pics/?dir=vextra
                      Just use any Nvidia card. Download Latest drivers, this is a must. They include an option to have custom resolutions!!!
                      Make a resolution at 856 * 480 I think it was. You will then have to adjust screen position from within the same Nvidia software, and in the monitor too. I think my refresh rate was 70.
                      Then look in monitor information in lilliput menu it will show 848 * 480.
                      And the bonus media car widescreen skin covers the whole screen no black bars.
                      The trick is installing lastest video card drivers!!!!!!!!
                        I just chked my nVidia properties GeForce4 MX440se and it has up to date drivers... Supports ***** Loads of Resolutions including 848x480 without having to create a custom Res.. although that option is available also...
                          Some cards were never designed to support such resolutions, the driver know which card you are using so dont put the odd resolutions in as a standard option.
                            So will I be ok using this card?? http://www.dvcentury.com/Merchant2/...ode=96-230-9205
                              that link took me nowhere, I have a 4 Nvidia cards aroung the place, they are all different models. I use anything from an old tnt card and up the lastest drivers work with all and give all options.
                              Maybe find someone with an older card and try for yourself, you may pick something up on ebay cheap. Its exactly what I have done recently.
                              Just remember the native res for the liliput is 800 x 480. And differnt monitor inf files will allow certain resolutions and some wont on the standard windows properties are.
