In-Dash DWW-7VGA does not fit Subaru Impreza WRX STi
  • In-Dash DWW-7VGA does not fit Subaru Impreza WRX STi
    Well I got my screen today and it didn't fit without me modifying my stereo cage, and now I have to cut a little bit of plastic off the sides of the bezel where the screen slides out. It's like 1/2 cm wider than the bezal.
    No problem, if I need a new bezel, they are 50 buks online.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Do you have the link to that store? I am looking for one for my 1997 Impreza
      Bezel availability on-line?
      Where can you order a replacement STi bezel on-line? I'm trying to find one so I don't hack up my current car's bezel!
      thanks
      -G
      -G
      try the AutoTouch FrontEnd
        thanks
        -G
        Gremlin, you can usually find this part on www.nasioc.com, as well as pretty much any other part you could want for your car. Look in the "private for sale" forum in the "classifieds" category. People are usually selling them from parting out wrecked cars.
        2002 Subaru WRX - Silver
        -FP18G turbo
        -Walbro fuel pump
        -Modified OEM 840 CC Injectors
        -TurboXS: UTEC, turboback, uppipe, intake
        -Blitz FMIC
        -STI cluster
        -17"x7.5" SSR Competitions
        -Tein Flex coilovers
        -NOS 50 shot
        -2004 rear conversion
          thanks
          -G
          heres another link for the bezel
          http://www.subaruparts.com/cart/?pn=66065FE090
            Just out of curiousity, what are the dimensions of your screen w/ it's casing?
            -FP18G turbo
            -Walbro fuel pump
            -Blitz FMIC
            -STI cluster
            -NOS 50 shot
              The screen is 1cm wider than the STi outer plastic bezal.
              www.digitalww.com
              Other than that, the screen works great. The angle is good. I had to modify the cage to fit it, and now I'm going outside to shave some plastic off the sides with a Xacto knife. If that don;t work, busting out the dremal, but I don't want a rough finish and I don't want to sand.
                www.digitalww.com
                Leslie - are you able to provide the exact dimensions of the in-dash housing including the size of the plastic bezel ? I'd like to see if it would fit my S40 dash without having to trim the dash. I asked Armen about it but there's no reply so far.
                  how well does the in-dash monitor work?
                  Can you tell me if the in-dash monitor works okay? I also have a WRX STI and am trying to choose between fitting a Xenarc 7" into the double DIN space or using an in-dash pop-out thing. I've been warned against the pop-out type because of the flex/etc. when you try to use it/press buttons. But, I'm a bit worried about the huge amount of work required to put a Xenarc in the double DIN space (removing the Xenarc from its case, working out brackets to put it in place, and somehow making it look factory installed).
                  Quincy
                    Works perfect, I gotta post pics, adnd a small how-to. Later.
                    I'll never get a stationary screen as long as glare exists. My screen moves where the sun ain't.
