where to buy DF19L-14P-1H 14 pin LVDS cable?
  • where to buy DF19L-14P-1H 14 pin LVDS cable?
    same problme as with my inverter just that i need an LVDS cable other than digital views
    01 blazer, LS1 engine, TR 220/220 cam, vig 3200 stall, 5.3 stage 1.5 ported heads, titanium retainers, APR harden push rods, dual X magnaflow 2.5's
    Interior: AutoMeter ultra lite's, panasonic cq8100u, kicker 8" L7's, kenwood 800 amp, PS/2,
    The cable connector socket you'd need is a Hirose DF19-14S-1C, shown here:
    http://rocky.digikey.com/WebLib/Hiro...9%20Series.pdf
    In theory you could make your own wiring, but the connectors are hard to find (digikey doesn't have them in stock - you can order 1000 at a time, if you want), and crimping the tiny connectors requires an expensive tool.
    Digikey does offer pre-made jumper wires with other Hirose connectors, but only up to 12" long.
    With the connector shells and some pre-crimped wires, you could make your own cable.. neither of which is currently available, apparently.
