Moniter Questions
  • Moniter Questions
    I was wishing I would find a Sticky in this forum that would possibly cover some of my questions, I used search got some answers, here is whats left that I feel i need a better answer for:
    whats the advantages of getting a moniter with VGA over the typical LCD
    does a touchscreen work simply as a mouse?
    i am looking for a 1Din Screen What should i look for? I see screens for 100 but i dont want something cheap. I want a screen that will give me a nice output I am not crazy on touch screen. Its nice but i dont want others touching my moniter. What adivce for a moniter would u all give?
    i was looking at these 2 moniters
    http://www.digitalww.com/LCD_TM_701L_BLACK.htm
    http://www.digitalww.com/DWW-7VGA.htm
    Thanks for your help.
    Shocka
    You cant say VGA vs Typical LCD... the issue really is VGA vs NTSC/PAL. VGA, XGA in most of the LCDs mentioned on this site supports a maximum resolution of 1024x768 and can take a signal directly from a computer's VGA out.
    NTSC/PAL LCDs have a maximum resolution of 640x480(at best). Also it requires your computer to either have a composite out or S-video out. S-video out is common on alot of mini-ITX boards. However s-video can sometimes leave something to be desired. Image quality is also not usually as good on these.
    The biggest issue is the resoultion though, the higher the resolution the more information(albiet smaller) you can display at one time. This becomes and issue when using GPS software that has lots of buttons and readouts.
    For the two links you gave me the more expensive VGA one would be the way to go if you MUST have single DIN. However as im sure youve noticed most people go for modding a 7" widescreen to fit in a 2DIN slot.
    Yes a touchscreen acts just like a mouse in essense.
    2003 Subaru Impreza TS
    Staus: Done.. too lazy to make pictures lol.
      maeveth, thanks for the response. As for your advice about using a 7" widescreen, i have an RX-8 and i dont want to get rid of my stock unit. I am actually getting a custom enclosure made that would accomodate a 1din unit.
      if you have seen the interior of an rx8 its not that easy to just stick a 2din unit in there.
        The best option would be to check out the Lilliput 7" VGA LCD group buys in the for sale forum, and this: http://www.digitalww.com/indashhousing.htm
        oh, and this: http://www.digitalww.com/VGA_Lillipu...ash_HowTo.html
          briang that seems like too much work.. imnot too good when it comes to soldering stuff anf playnig with wires i wish liliput made a nice 1din display
            I will be making in-dash lilliputs very soon so email me and we will talk.
            Armen
            armen@digitalww.com
              As far as I have seen all the 7in vga screens have a 800x480 resolution and scale inputs up to 1024x768 down to 800x480. Also all the 7in screens that only take RCA I have seen have a resolution of 400x240.
                I know the stock RX8 screen is RGB and not composite what kind of quality should I expect from that as to VGA?
                2005 Ford Mustang GT <- - - UPDATED PICTURES
                2003 KAWASAKI Z1000 - CUSTOM MODZ
                MBK (AIM = IllMBKllI)
                  well i decided that buying the stock navi screen for the rx8 would be too expensive.. instead i am awaiting a custom 1din dash pieace that wud fit in the navi section... i wish i could just get the flip up portioni of the navi and put my own screen in there.
                    I thought people were saying you could buy the part from mazda? Because what were to happen if it broke right?
                      Or just use this
                      http://www.rx8club.com/showthread.php?s=&threadid=15088
                        mkbrown i saw that.... no way i am doing that.. you can see a screen sitting there and just looks too attractive to theifs.
                        i am going with this option
                        http://www.rx8club.com/showthread.ph...5&pagenumber=1
                          omg thats even worse looks like crap
                            that is not the actual pieace... people are having it recreated by a company in texas
                              Just tap into the stock navi screen. I know it works its just a RGBS LCD.
