Warning about In-dash LCD panel mount (TM-701L and DWW-7VGA)
  • Warning about In-dash LCD panel mount (TM-701L and DWW-7VGA)
    Hello All,
    Edited - 03-30-2004
    I should rename this: How to completely embarrass yourself in front of everyone. The major problem here was that _I_ did not know the difference between an ISO mount and a DIN mount. My car is ISO and the TM-701L and DWW-7VGA is DIN. That's where my trouble began. So excuse my *****ing. I'm a bonehead.
    For those is the same situation: you can mount the DIN sized unit in an ISO dash by using some washers as spacers (for your other ISO stuff in the same bracket) and drilling some new holes in the bracket. It'll be tight coming thru the dash, but it should fit snuggly.
    Below you'll see mention of cracked bezels. Armen told me that 70% of his last shipment had cracked bezels. He's since got replacements and is shipping them to me.
    Cheers,
    Tom
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Tom
    I can send you 2 new frames which are not cracked.
    When I received my order of these housings, 70% came with broken frames and none had any hardware. I just received replacement frames so email me and I will talk.
    Armen
    http://www.digitalww.com
      where would be the fun if everything fit together perfectly?
      im still not at that stage of installing..and i still havent picked out a screen... but i always had a feeling that they were a little larger than the size of an actual head unit.
      thanks for the warning!
      rebuilding carpc... kinda..
        Armen,
        Sorry, I didn't want it so sound like I'm a disatisfied DigitalWW customer. I'm not. Dealing with you has been no hassle. If you've got replacement bezels in stock that would be great. I'll email you.
        I had planned to call you today about it, but I got busy with work.
        Thanks,
        Tom
        So far:
          Yeah thanks for the warning....I just assembled my Gain screen into the in-dash housing...Armen's instructions are pretty good, I thought I could get away without the double sticky tape to offset the touchscreen...turns out the tape is needed, was the touchscreen detecting the edges being presed against the housing. I added the tape and it works nicely now.
          I haven't installed the housing in my car yet however I assumed it would be a bit difficult and not line up line a standard car radio. I am a little disappointed in the bezel, mine is a little banged up like TOM2112's. Armen,
          Can you send me a new bezel also along with the two screws for the screen housing?
          My Celica Carputer Install
            I got the in dash housing without electronics. Originally I planned to use the Lilliput as per the downloaded instructions (glad there are directions - would have taken some time to figure all that out). Then, the NightRider bulk buy fell through. Then, all the posts about Lilliput vs. Xenarc.
            So, will a Xenarc fit in this housing? Anybody try it? Anybody try any other monitors in this housing? Did I see a Hitachi 7" touchscreen? How's bout this one?
            No, I didn't Search for the answer but, have read "all" recent posts and haven't seen this question.
              I believe Armen answered this before - yes, the Xenarc will fit inside the in-dash housing.
              I also received the housing without screws, plus one of the plastic parts inside had broken. I've emailed Armen to ask for replacement parts. The good thing is the housing fits perfectly in my Volvo S40 - the extra 1/16" did not cause any problems.
                I'm almost positive that the DWW-7VGA units for sale at DigitalWW come with Xenarcs. I got mine with Lilliputs due to a shortage on the the Xenarc touch kits at the time. Armen offered to put Lilliputs in instead to hurry the order up. So I went for it.
                So far:
                  Originally posted by tom2112
                  I assumed that the housing would mount right in my dash, just as easy as my aftermarket Sony head unit. Not so.
                  What you should be aware of is that the housing is a bit wider than most DIN mounted hardware. I have two of these housings and they are both the same. They are both wider than my Sony head unit by about 3 or 4mm. The front of the head unit barely fits thru the DIN hole in my dash. I had to force it. It's a good thing that the plastic of the dash in my Mitsubishi Eclipse is a bit elastic.
                  You are talking about ISO mounting, not DIN mounting. There is a difference between DIN and ISO. ISO is without the sleeve that goes into the dash that the aftermarket stereo gets installed in. DIN is with the sleeve in the dash. So there should be a 3 or 4mm difference. This housing sounds like it is DIN mountable but not ISO mountable and that is most likely why it doesn't have the correct holes in place for you. This is also why it fits correctly into Shchua’s Volvo, because his car is a true DIN mount. The eclipse is ISO mount. I hope this helps explain what is happening.
                  Steve
                    Ahhhh!!!! Now it all makes sense. Thanks for explaining that, Steve. (even though, I now feel like a real bonehead!)
                    So far:
                      I am a stereo installer din refers to only the size of the hole din size is 2" by 7" ISO mount means the unit is mounted with brackets and screws on the side and sleve mount means the unit mounts in a sleve that is fit in to the din or 2 din ect. hole what ever size hole in the dash and as you saw in your car not all ISO mount units bolt right to your brackets a toyota bracket is different from a nissan or mazda bracket and there is no standard for them
