Lilliput USB driver CPU usage question.
  • Lilliput USB driver CPU usage question.
    I am using an EPIA 800 system with 512MB memory, WIN98SE, and Lilliput 7"
    4 wire resistive touch screen. I have installed the lateset driver from digitalww and also have current drivers for all my hardware.
    Now the question is, using the hardware monitor in WIN98 with the touchscreen enabled "installed", I see 100% CPU usage statistics. Remove it "touchscreen", in this case simply remove USB cable and just use the display portion of the monitor. I see CPU usage drop to 20%. Anyone else notice this? I would have to do some more digging, but is the monitor continously polling the USB bus for location?
