10.4"+ Monitors Help
  • 10.4"+ Monitors Help
    I need help finding the right monitor source.
    Here are the requirements:
    10.4" ~ 13.2"
    Wall Mounting Option
    640x480+ Resolution
    250+ nits brightness
    Readily available
    Cost less than $600
    Allbrite ones seem to be out of the picture now. Datalux is outrageously expensive. Panoview has no wall mounting option.
    Thanks for helping.
    I have more questions. I am guessing you want vga and touchscreen?
    ATVMS.com
      Forgot to mention.
      VGA and NO Touchscreen.
        No touchscreen so why a 10.4"-13"? You can get a 15"-17" lcd from about anywhere for under $600.
        ATVMS.com
          That was the first thing considered.
          Unfortunately, 15" may be too big. 10.4" would be perfect for the task. 12.1" wouldn't be bad either. 7" was proven to be too small.
            So what are we trying to accomplish. Knowing what it is going to be used for might make the search easier.
            ATVMS.com
              It needs to display important information to the driver, such as destination address, important messages, etc. No driver input is necessary.
              7" was fitted and proven to be too small to see that info. It was decided that a 10.4" would be perfect for the task; 12.1" wouldn't be bad either, but 15" would be an overkill and may have installation complications.
                Check out http://store.earthlcd.com they should have something you could use..
                Maybe this..
                http://store.earthlcd.com/s.nl/c.318...it.A/id.628/.f
                Or this
                http://store.earthlcd.com/s.nl/c.318...it.A/id.634/.f
                www.DurangoSUV.com
                  Originally posted by The Durango Kid
                  Thanks.
                  Those 2 are too dim. One is 100 nits and the other is 180.
                  I looked through their site a few times already. I haven't seen a monitor that would work well for this purpose.
                    Originally posted by P4_2.66GHz
                    Thanks.
                    http://cgi.ebay.com/ws/eBayISAPI.dll...124307289&rd=1
                    datalux 4 cheap
                    has touch, but that can be removed/resold (ill buy it if you win the auction, i just got a 10.4" w/no touch and i want it)
                    hurry, only 2 hrs left
                    edit:
                    http://cgi.ebay.com/ws/eBayISAPI.dll...092697018&rd=1
                    another option if you miss the first one - NO way these things go over 300-350....i would be surprised if that first one gets much above $300 at all.
                    anyway, good luck
                    Cheap Laptop, great for Carputer!
                      datalux 4 cheap
                      edit:
                      anyway, good luck
                      Thanks for the links.
                      The thing is, I need a source where I can get those in high qty.
                      The pricing Datalux gave me was out of this world.
                        i ddint see where you specified high qty...sorry - in that case, have you contacted earthLCD to see if they can give you a bulk discount?.....otherwise good luck!
                        btw, how many are you getting/what for?
                          For now, that's a "consulting project." Qty is yet unknown, but they need more than a dozen.
                          Resolution must also be 800x600 or better.
                          I know this much:
                          "It needs to display important information to the driver, such as destination address, important messages, etc. No driver input is necessary."
                          I guess I'll have to check with EarthLCD again.
