lilli positive or negative
  • lilli positive or negative
    on the lilliput cable, which one is the positive and which in negative, i will be hooking this up tommorow, on the cable, one has stripes and the other is solid, on my power inverter, the strip cable was positive, i am not sure if that is the same on the lilli
    bingo.
    Mine needs to be updated.
      bingo, as in the stripe one is positive, and the one with the description of the type of cable is negative, so i hookup the stripe one to the yellow cable on the fdd power plug, and the one with the tiny writing to the black on right beside the yellow,
      thanks for the wuick reply
        Another easy way to check is crack open that cheesy $0.01 cent cigarrette lighter plug. Center point is positive, sides are negative.
          cool, since i will be using the cable on the egg adapter, am i wiring it righ to the opus, positive to yellow, which will be the center, and the negative, the outer to the black, also do i hack off the egg and jsut use the cable since the egg is a worthless peice of crap regulator
