Need replacement connector for Lilliput
  • Need replacement connector for Lilliput
    I have damaged the connector on the back of the LCD. Does anyone know where I can get a replacement. I just need the beige colored piece that pivots up and down to hold the ribbon cable in place.
    Thanks!
    The toothpick solution
    What do you think of this solution?
    I found that just gluing the broken piece didn't exert enough downward pressure on the cable. I tried 4 different glues: Loctite SuperGlue Gel being the best because it was thick and didn't run down into the connector and it sets within 30 seconds (because I couldn't find a good way to safely clamp it while the other glues set in 20-60 minutes).
    However, in the end, a wooden toothpick worked perfectly and I didn't use any glue at all. The duck tape doesn't do anything, I just didn't want to remove it after finding something that works.
      Hi
      I've just fouind myself in a similar position so I'll give your method a try.
      I also need a replacement ribbon cable - it's the same one that's shown in your pic, the one that goes from the back of the panel to a circuit board.
      Any ideas where I could get hold of one?
      JB
        This solution isn't perfect. Anyone know where I can get a replacement connector (see pictures in first post).
        When I put any pressure on the right side of the plastic case, the screen goes blank or appears scrambled.
        Replacement cables are available for $3 from www.digitalww.com
        1997 Toyota Celica
          I have the exact same problem, does anyone know where to purchase broken latch?
          Dual Lilliput's 70NP/C/T
          Syntax SV266AD KT266A
          AMD Athlon XP 2000
          Viking 256MB DDR
          D-Link Wireless 802.11B
          Seagate 120GB
          OrbitMicro 250W DC/DC converter
          SII Wireless Audio Link
          Digimoto OBD-II
          Earthmate GPS
          BU-303 USB GPS
          D-Link Bluetooth
            I have the same problem, but I can find source here(Taiwan). I'm planning to replace the beige cover with new one only. Otherwise, it's also not so difficult to replace whole connector.
            Anyway, I just order this parts today. Once it's done, I'll see what I can have help to you guys.
            Dominic Lu
              Thanks dominiclu! Let us know how it works.
              I am going to try ordering a couple of different connectors from www.digikey.com and see if any of them fit.
                Digi-Key Part: HFR40CT-ND appears to be very similar. I've got it here and I will try in the Lilliput when I mount the screen in the car.
                I've also orderd HFJ40CT-ND (close, may work) and WM5684CT-ND (definitely won't work).
                  Has anyone found a replacement for the header and ribbon cable?
                  AMD Athlon XP 2000
                  Viking 256MB DDR
                  Seagate 120GB
                  Digimoto OBD-II
                  Earthmate GPS
                  BU-303 USB GPS
                  D-Link Bluetooth
                    Seems a lot of people have this problem. Any tips on avoiding breaking it? I'll be ordering a lilliput soon, and don't want to destroy it when I take it apart...
                    Zen Fat Loss
                      digitalww will sell you a cable for something like $3. Its a Parlex 40 pin 0.5mm. I got some free samples from Parlex.
                      2004 Subaru STI
                      AMS CG65 2.4Ghz P4 w/512MB DDR, 40GB HD
                      Audigy2 ZS, Xenarc 700TSV, Gyration Media Center
                      WinXP Pro, ME 2.1, AudioBahn 5100T Amp
                      AWT10X Sub, JL XR100-CT tweeters
                      Sony XPlod fronts, Kenwood Excelon rears
                        yea, he sold me two that were the wrong type, apparently there are two types, i think one style is on one side and the other is on one side and the other side on the other end. Its been almost 3 months since i bought my Lilliput from him with no more messages from him......HHmmff
                        When i separated my cases, the ribbon cable was only 3" long and that screwed my header up, and trying the toothpick fix, just screwed my cable, not that its a bad fix, but my cable was too short.
                        Sure wish i had a cable to fix this display, Armen?
                        AMD Athlon XP 2000
                        Viking 256MB DDR
                        Seagate 120GB
                        Digimoto OBD-II
                        Earthmate GPS
                        BU-303 USB GPS
                        D-Link Bluetooth
                          Bambooracer - did you ever get the HFJ40CT to work? I've got a semi-busted connector (only one side will latch) and will probably have to replace it once the car jiggles it lose...
                          I sent an email to digitalWW also, trying to see if they had any of the connectors.
                          Does anyone know if the lead pitch on the cables? I'm guessing 0.5mm...
                          - Dan
                            Nope. I ended up stuffing the cable into the connector and using glue with a toothpick to hold the cable down. The duck tape didn't help.
                              anyone found the correct part number?
