Lilliput New REV!?! HELP!!!
  • Lilliput New REV!?! HELP!!!
    Hey guys, i recently just ordered my third lilliput 7" touchscreen from ebay (wifi buys) and i noticed that one of the video ribbon connectors(the one on the controller board) is different. Instead of having a hinge like the connectors on other lilliputs, it has the same type of connector as the button ribbon connector, were you have to push on both sides. The sad news is that i killed my ribbon cable and when i ordered a new one it didn't work because the on one of the sides the pins were exposed on the wrong side. Since the new connecter need the pins to be facing up. (the hardcore lilliput modders know what i mean.) so i need a ribbon cable that has pins exposed on the same side on each end.
    I need to know Three things:
    1. Do people know about this different connector that could be ******* up some newbies that have only worked on one screen before?
    2. Where can i get this different ribbon cable?
    3. What does it mean if your screen just lights up white, where there is no ribbon cable? (My other two screens used to show some wierd pictures when there was no ribbon cable connected like the JP logo.)
    PLease Help mee!!
    email: [email protected]
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    I will try to get pictures of the new connector posted later today
    S2000 Carputer
      cant you just solder it ?
      CarPC install is starting to come along again...
        HAHHA, i actually tried cutting the cable in half and soldering each oposit end, but the cable didn't work.
        S2000 Carputer
          Since my screen is white does it mean it could be dammaged? or does it just mean the cable is dammaged?
          S2000 Carputer
            if its all white it means that some pins may be connected while others are not. It could be due to a damaged cable or damaged connectors.
            I think I know what you mean about the connectors. You mean that the connectors from the VGA controller card to the LCD right? They are the non-flip type? You do know you can fold the ribbon cable?
            New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
            SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
              I think its too late now
                holy **** i never thought about that, im going to try it tonight.
                THANK YOU!!!!!!!!!!!
                Its not too late because i purchased 3 replacment cables just in cast!!
                S2000 Carputer
                  folding didn't work
                  S2000 Carputer
                    something could be wrong with your connectors. try checking for the ribbon-pin alignment in detail. can you pull it out if you try? if you can then the cable isnt tight enough
