20x4 LCD problems
  • 20x4 LCD problems
    having a problem on my char LCD - some of the lines are shifted left by one...
    It's fine indoors on my home PC, but shows this in car. GROUNDING I hear you shout, but everything is grounded properly
    any idea's? could mediacar have gone screwy?
    James
    www.digital-car.co.uk - The UK CarPC Forum
    A car is a great source of noise, try the same cable outside the car or with the car battery unplugged...
    My cars
      tried running cable outside, running it next to PC doesn't seem to help.
      strange part is it changes sometimes - sometimes a few lines go where they should be - and some characters are misdisplayed, which probably says electrical noise rather than software to me...
        OK interestingly i've tried a few other apps, smartie lcd - produces all garbage, but the LCD plugin for girder displays perfectly, I'm beginning to wonder whether it's the delay's between the data sends ( i can set the speed of transmittal on the girder one... ) is this just because noise is effecting a higher speed - or could it be something to do with my parralel port on my M1000 ?
        PS. what mode shoudl the lpt port be in for LCD ? ( ECP/EPP etc )
          right - it gets wierder, tried an EPIA 800 in the car - everything is fine under any LCD software, so it's something to do with either hardware of M1000 or my software - ( i've reinstalled driverlinx I/O driver and reinstalled parallel port driver
          could I have a bad mainboard?
          James
            If you have ripple on your power supply, it could cause false triggering on the display.
            Dual Lilliput's 70NP/C/T
            Syntax SV266AD KT266A
            AMD Athlon XP 2000
            Viking 256MB DDR
            D-Link Wireless 802.11B
            Seagate 120GB
            OrbitMicro 250W DC/DC converter
            SII Wireless Audio Link
            Digimoto OBD-II
            Earthmate GPS
            BU-303 USB GPS
            D-Link Bluetooth
              running an opus 150W - I can rule that out becuase i can run an epia800 machine off it and screen works fine. Suppose all i can do it reinstall XP, if it then doesn't work suppose i need to RMA the board
              James
                Some boards have stronger output on the parallel port than others... I had the exact same problem with mine. I either had to shorten the cable running to it, or use a different board, both fixed the problem. It would happen every once in a while. Weirdest thing. Have you tried a shorter cable just for grins??
                Tidder
                Try RevFE
                  yup afraid so, I can't understand why two differnent machines will drive it fine, starting to think the board is faulty - anyone else running a char lcd on a M1000? the parallel port can't differ all that much from the EPIA800 !
