calibratin Lillliput Touchscreen
  • calibratin Lillliput Touchscreen
    not sure how you do it, in the middle it's fine but on the outside 1/2 inch or so it doesn't seem to want to work (which means now closing, minimizing, or maximizin, and also no taskbar to get to stuff.....). If somebody can tell me how or provide a link i'd be greatly appreciative.
    I had exactly the same problem with mine lilliput until i went to heaven yesterday... I tried both 25point and 4 point calib, but the same thing everytime...
    First i tought that it was the edges of the frame that was to close to the touchscreen so i put a little tape between the frame and the screen but i still had the same prob.. and now i have now screen at all..
      I also had the same problem. I believe in my case the glue on the right border used to glue the layers of the touch screen thinned out, causing the two layers of the touch screen to short in the upper right corner. this problem got worse and worse as time went on causing more of an arc.
      All works well after replacing the touch screen. It now works better than ever, I never needed to calibrate this new panel.
        replace touchscreen.... is that what lilliput call quality... new screens hasent even been tested so everything work...
        Im already on my second touch glas and i wont buy one more, it starts getting expencive..
          I have the exact same problem, and wasn't able to get the 25-point callibration to work (it has the target and acknowleges when I click on it, but then continues to display the same one target and doesn't do anything else?). Anyone?
            yup i just got the same screen and am also having the same problem. my screen sometimes works great and i turn it of and on again and it works horrible. i'll touch one spot and see the cursor like and inch below my finger
            the flesh does not determine what is within.
            carputer is in begining status
              i have had enough of this lilliput thing for now.. and remove the touchscreen and build a LCD projector instead of it...
              i will replace my carpc and lilliput with a stock navi from VW as soon as i have som spare money...
              It have composite video in so with a big deal of luck i will still be able to use my car pc... if not i it will be rebuild to a multimedia terminal in my livingroom
