Please Help!! w/datlux 10.4
  • Please Help!! w/datlux 10.4
    whats up everyone,
    well this is whats going on i am running a epia m1000 that only puts out3.3v for the screen signal and my datalux screen needs 5v to detect a signal, now this is where im stuck my datalux is the captive touch model and it has a few different wires and boards then does the resistive touch model, so i have searchd for and upgrade to make the datalux 5v on the captive touch and i cant find one,just for resistive, and its a little different. i have read that you can use a vga booster but i cant find anyone that has actually used one of these to boost the sigal to make the screen turn on. I would much rather pay 50$ for that if i knew it worked, then start cutting wires. So i was wondering if anyone out there knew how to upgrade the captive touch model or if anyone knows if the vga booster will work? any information will help. I thank you very much.......its been a long journey.....
    The M10000 also provides 12V, just use a $1 regulator called a 7805 from Radio Shack. It's super simple, it has three pins. The middle is the ground, one is 12V in, and one is 5V out.
    Chrysler 300 - Fabricating
    http://hallert.net/
      where would i put that regulator between witch wires on the screen? im really sorry im not to good with these thing and another i dont wanna screw anything up, and thank for the input im gonna go get 1 of those tomarrow, hopefully i here back from you cause this sounds to easy .. thanks
        http://www.radioshack.com/product.as...%5Fid=276-1770
        exact link to regulator.
        No idea where you would connect it but my guess is into one of those http://www.bbdsoft.com/video.html so to basically jump the voltage from the VGA out on the mobo to the actual controller on the screen. it goes in between but not sure which pin.
        Welcome, cdm.
        You last visited: 09-13-2006 at 02:42 AM
        Private Messages: Unread 0, Total 3.
        Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
          ok thanks im going to go down and pick up the regulater now all i can hope for is, for someone to know where abouts it goes, well i kinda have an idea where it goes but if someone out there knows excatly where it should go and they could give me some info that would be great and highly appreciated..
            it goes either on the hsync or vsync or both. though i am not sure if you can kill the controller if you mess that up.
            http://www.kvmextenders.com/nav/item.asp?item=4673
            or similar should do the trick safely, though it's more clutter in the way.
            Welcome, cdm.
              I'm looking at a similar problem with an Epia M10000 and a Dr-Berghaus panel. I tlooks like the berghaus screen needs 5v sync too, as If I try to boot with the TFT on, it fails. Shows the Bios screen, then goes black and nothing. If I boot with a standard monitor, and swap them, it displays fine until I reboot.
              I'm in touch with Daimond point about this issue, and they are waiting for a reply from Kontron Germany regarding the problems I've been having.
              4x4 in a turbo stylee.
                Is this what you are looking for??? Not sure, hope it helps.
                http://www.mp3car.com/vbulletin/showthread.php?t=15610
                FrodoSkinner v1.1
                  That's a solution to the problem, but not with the hardware I have, but should work for Burns-1.
                  Mine is a single board for everything except to inverter. there isn't really any wires to go into the add the extra voltage.
                    Yea i checked that out and that one wont work cause is it resistive touch and i have captive, it has a different board and some different wires, im sure it may work but i dont know how do translate that resistive screen into captive i could take a picutre of it, if anyone can help me out with narrowing it down.
                    Hey and let me know what you here back about your problem with your screen and the epia1000, is there anyway to alter the board to send out 5v, also does anyone know if a vga booster will work?
                      Booster technically should work. I haven't tried it but might within a week as i got another datalux, this one needing 5.0V (arriving today).
                      Another solution, you can dig up an old 8 or 16mb (or whatever) video card and use that one. It could be tricky since you really don't want the VGA board to move in the slot at all but if all else fails, it's always an option.
                      It's annoying but that's what we get for not spending 800$ on a flashy new 10.4 touch
                      Welcome, cdm.
                        Well, the original screen I bought was an Ebay special for 90GBP, and I recased it, and added one of armins touch panels for another 100GBP (ish).
                        Then I managed to short the controller, and had to buy a new one (berghaus) 200GBP.
                        So just sgort of 400 GBP. Of course intially it worked great for under 200, so it was great, then I broke it, and 400 GBP is stil cheap for a 10.4", but stupid compared to what I could have bought an 8" Lilli for now (the 8" weren't out then, and the 7" were tricky to get in the UK), especially as I'm having trouble getting the Epia and the berghaus controller to work together.
