8" lilliput in a double din?
  • 8" lilliput in a double din?
    Has anyone installed an 8" lilliput in a double din? got pics?
    I tried searching to no prevail. They seemed to be dropping in price.
    Thanks.
    MJH
    mykolJay
    99 Accord coupe
    http://www.geocities.com/accordpc
    My Project Thread on mp3car.com
    who has an 8" in stock?
    fitting them into a double din might be tough...you'd have to see if they were any wider than the 7"s...nevermind the height. you could probably do it without the housing
    rebuilding carpc... kinda..
      http://cgi.ebay.com/ws/eBayISAPI.dll...100860000&rd=1
      Here's one from electronicar
      mykolJay
      99 Accord coupe
        well thats about 8x6.5"...im assuming with the housing. measure the opening and see how much its off by
          way too big for a double din. There's a double din concealed behind this...
          Remember, it's a 4x3, and the 16x9 7" are a tiney bit larger than the double din.
          car computer rev 5: 8" lilliput and usual suspects
            thank for the quick replies...i'll stick to getting a 7"
            mykolJay
            99 Accord coupe
              where there's a will, there's a way! the lillput 8" is an exceptional screen, just need to find somewhere to stick it...
                does anyone know the size of a double din off hand...unfortunately, I don't have my car nearby. I live in NYC.
                From looking at a Mazda thread, they said doubledin was about 7.5 x 4.2 x 7.
                Can that be confirmed?
                I wish I could see an example, I'd rather not cut the dash too much. or have to extend the buttons.
                mykolJay
                99 Accord coupe
                  you don't have much of a choice in the matter. the 7" lilliput bezel, plain and simple, is larger than a double din...
                    I have a 7" Lilli in my double din openeing. I can tell you that the panel itself (bezel removed) is slightly larger than the opening. The viewable area of the panel is just a bit smaller than the opening. What I did was trim the bezel down to be the same size as the panel itself and then flush mounted it from behind. There is no way an 8" is going to fit into a standard double din.
                    2004 4runner
                      well. i ordered a 7" lilliput from MP3car store. I'm happy. Thanks for your replies.
                      mykolJay
                      99 Accord coupe
                        RobieWP... could you measure your screen and give the dimensions of just the lcd
                        that shows the image? Curious if I could flush mount one from behind with minimal trimming
                        of double-din socket...
                        Thanks in advance!
                        CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
                        Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
                        Display: Lilliput 7" TouchScreen
                        CarPuter Install
                          do some trig. it's 3 by 4 and has an 8" hypotenuse
                          For my mount in the jeep the screen is taking the place of a double din slot plus a little height.
                            So it's like 6,4" x 4,8" viewable...
