Lilliput 4-point and 25-point calibration?
  • Lilliput 4-point and 25-point calibration?
    the touchscreen works great, but i can't get to the "x"'s at the upper right corner of the window (in Windows) to close a program, or even to hit the Start button on lower left corner, or anything minimized in the task bar. the touchscreen just doesn't see these areas. i think that i need to use the calibration tool that came with the drivers.
    when i run the calibration tool (4-point for example), it shows a little blinking "x" in the lower left corner. you are supposed to touch the X when it stops blinking. but the time that it takes between stopping blinking and failing the calibration is like half a second or less! i can't press the X fast enough for it to register. i automatically fail the calibration. is there any way to do this?
    You're supposed to press and hold the X, then when it beeps, press the next one.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
      ha! the wording on the screen isn't worded very well, so i wasn't sure. that makes alot more sense... i'll try it.
      thanks!
        Yea, took me a few times to get it, it says touch, i thought i was just supposed to keep tapping.
        2 Kicker Comp 10"
        Check it out?!
