Laptop Display -> VGA + Power
  • Laptop Display -> VGA + Power
    Ok here we go. I've searched around a bit and realized that I should probably be able to convert the actual data wires to a 15-pin VGA connector.
    I've been reading that you need some kind of controller? Is that for the data or for the Power?
    I've got a working ac-dc inverter that came with the laptop. Although, if I'm going to connect it to a regular VGA connection, I would need external power right? Is there a way to convert 12V car power to power the display?
    The display is a Goldstar 10.4" nr: LCA4VE02A
    DC-AC inverter: DAC-07B004 it says 1.5A / 32V
    There are seven wires coming from the laptop to the inverter (from the left):
    black,brown,red,orange,yellow,blue,white.
    Inverter to display got two wires, white and pink.
    Is this impossible?
