New Lilliput Touch Panel install have question
  • New Lilliput Touch Panel install have question
    I got the new touch panel from Armen (thanks), it installed fine and solved my problem, but now I am curious, (possibly dumb question coming up) , do I need to remove the plastic sheeting from both sides of this panel or just the back, is the touch panel actually the plastic? cause I put it on with the plastic sheet still on the front and it seems a bit dull.
    thanks in advance!
    How in the world would you put the special AirPort card in a PC? Mine is a Mac anyway but it's too old to AirPort. I just use a zip drive to transfer.
    there is usually a screen protector on (film). You can peel it off. Its purely for shipping purposes. You coulnt pull the 'touchscreen' off, without really trying, WITH the casing off.
    Jamie
      there is no casing, its just the touch panel, my lilliput is in dash.
        duno m8,
        email armen probably best
