Ramline Mobile PC
  • Ramline Mobile PC
    Hello
    Question about this LCD.
    I found it from the trash can.
    Idea is to place it into car and connect with pc.
    It uses lpt put I cant cet it working.
    pic 1
    pic 2
    pic 3
    inside
    inside 2
    Can you help me out with this.
    Sorry for my poor english
    Regards
    you'll have to find the specs for it firstly.
    CarPC status: iPod, 3,456,217 songs so **** you
      I even contact the company who made this but they could not help me with specs.
      This much I managed to find out. It has been used in taxi-s
        Unlikely it uses lpt, more likely it just happens to have a 25-way D-plug. It'll be propriatory. It'll be a little black-and-white lcd, quite possibly with defined patterns too rather than a pixel matrix. I wouldn't even bother trying to get it working personally, without the specs it'll be nigh-on impossible, and if you do get it working, it'll be cr4p
        Try passing volts over random pins, see what happens If it starts to smoke, stop, and pass volts elsewhere
        If nothing happens, try 110/240 volts!
        GingerPrince
        Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
        Carputer Install - http://www.stuffandting.com/carputer/
        CarBox Software -- http://www.stuffandting.com/carbox/
          I consider it because I have 3 of them
          The voltage passed over pins should be 12v or ???
            If you really want to play I'd be more tempted to play with 5v initially (TTL levels). Probably one of the 4 corners will be a power line. If you have it open perhaps one of the wires internally is slightly thicker, or red? I'd guess that will be power. Pass 5v over that and a corner near it, see if you get any life.
            GingerPrince
