gamma problem after hibernation
  • gamma problem after hibernation
    Hi !
    I've got an epia M10000 and lilliput screen in my car.
    I enabled hibernation in windows XP and it works great.
    Only problem I have is when the pc starts up after hibernation, the gamma settings are wrong (too bright)
    When I open the configuration panel of the videocard (videocard is integrated on the m10000) and choose the gamma tab, it suddenly changes to the good settings (don't need to change anything, only select the gamma tab)
    So everytime I startup the pc, I have to go to the display control panel to set the gamma levels correctly.
    Anyone has a solution for this?
    thx
    Are you using MediaEngine? I get whacked gamma settings occasionally with that program.
    Chrysler 300 - Fabricating
    http://hallert.net/
