ATI 9600pro resolution setting with VGA and TV out
  • ATI 9600pro resolution setting with VGA and TV out
    I am running ATI AIW 9600Pro with both VGA and TV out. I find that whenever I have TV out on, I can only have the VGA at 60Hz and the screen won't fit in my Xenarc which makes it look bad. If I disable the TV out I could set my VGA refresh rate to 70Hz and the screen would fit perfectly in my Xenarc.
    Is there anyway to fix this problem so that I could use the TV out while still having a good image on my Xenarc ?
    Will using powerstrip fix this problem ?
    Honda Lagreat Carputer Project. Mobile Entertainment
    http://www.mp3car.com/vbulletin/showthread.php?t=33936
    Full Spec for mods check out:
    http://www.hondashowoff.com/profile.php?id=3766
    I just changed to a thicker better VGA cable and everything looks great. Now I set my Xenarc at 60Hz and there's no flickering. However there is one prolem when TV out is on. If I turn on overscan, te image will not fit in the whole screen. If i turn overscan off, there would be black bars on top and bottom of the screen. The only time i can have a perfect screen is when I turn TV-out off.
    Any solution to this ?
    BTW this is my first post for my car ! woohoo ! too excited..lol
      What are you using the tv out for ?
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        dido wtf reason would you want to use tv out on a xenarc...
