Lilliput USB
  • Lilliput USB
    I was just curious to know if anyone knew the correlation of the Lilli USB wire colors with that of traditional US USB wire colors
    Lilli= Red, Brown, Yellow, Darkyellow
    US- Red, Black, White, Green
    reds obvious and im guessing brown is neg and the 2 yellows are data
    anyone?
    throw a moon
    heuvos vin chevos
    NM figured it out,, for anyone who may ever want to know
    Traditional - Lilli
    Red ~ Red
    White ~ Dark Yellow
    Green ~ Yellow
    Black ~ Brown
    throw a moon
    heuvos vin chevos
      The other end of it (the TS controller inside) is stupid.
      Black = 5V
      Red = GND
      White/Yellow are normal.
        Black = 5V
        Red = GND
        Thanks,, another reason i wanted to know is Armen told me some of the wires in some new Lillis for the controller were mixed up so i tried reversing the 2 yellows as that seemed to be the most plausible thing to happen
        throw a moon
        heuvos vin chevos
          Those will probably just keep it from working until you get it right, but reversing the other 2 will release the magic black smoke.
            indeed..
            throw a moon
            heuvos vin chevos
              Traditional - Lilli
              Red ~ Red
              White ~ Dark Yellow
              Green ~ Yellow
              Black ~ Brown
              I know I'm bringing up an old thread, but I hardwired my lilliput to a USB cable using the above connections and now the touchscreen doesn't work. Has anyone else wired it up this way? Is there a better way to add a long USB cable to the end of the Lilliput?
              The only other thing I can think of that I messed up my wires/connections when installing the monitor in the dash, since it worked before the install with the regular USB cable.
              Dan
              1997 Corvette
