800 x 600 Xenarc resolution help!
  • 800 x 600 Xenarc resolution help!
    I can't seem to get my screen to get the 800 x 600 reso without losing the taskbar. I have installed the drivers that came with my Epia M-10K board and set the bios for 8x6. Anyone else had similar issues and fixes..
    I'm guessing that on the xenarc, just like my lilliput there is an auto-adjust for the screen in the on-screen menu somewhere. That should fix it.
      try changing you refresh rate to eith 60hz or 70hz or 75hz
        Agreed
        Kefka_Killer.owns(you);
          I had the same problem Refresh rater fixed it for me.
          The 2007 Scion tC + Infill G4 Project | DVDxml.com
            Please Let Us Know If It Works!
            BossTone74
              Yep , setting the refresh rate to 75 fixed the problem for me.
                Yeah but you will get annoying lines across the screen from time to time. It does this phenomenon on its terms not yours. Its random and ITS ANNOYING. i cannot find a way of fixing it. Seems the xenarc doesnt like 800x600 x60hz or at 75hz. At 85 it spazzes and says go away. You may even see a ghost image if you lucky. ROLL ON 800x480 driver VIA. . . .
