LVDS Single channel interface To MII10000
  • LVDS Single channel interface To MII10000
    Hi..
    Anybody who can help me to where to get: LVDS Single channel interface to a VIA EPIA M-II 10000 mainboard??
    Thnaks alot!!
    Just any place in Europe. best if it's in Denmark, Germany.. But anywhere have my interest!
    Glenn
    BTW, what does LVDS stand for ??? what is it ???
    Been wondering that for some time, sorry for the highjack
      It's a module for the mainboard, so you can connect a lcd display
        http://www.***********.com/product_i...roducts_id/253
        *********** = "L O G I C S U P P L Y"
        LVDS = low voltage differential signaling
          LVDS is a digital signaling standard use commonly in industrial PCs to communicate between the onboard controller and the LCD controller.
          It's similar to DVI in it's intend, ie keeping the path digital and thus eliminate the problem with V-sync and phase problem u see in using analogue controller for LCD.
          VIA sells 3 daughter board for the EPIAs: TTL, RBG & LVDS
          CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
            Has anybody an idea, what for the PIC-Controler on the RGB (TTL) interface is? Maybe the display is turned on, when the drivers are loaded?
            The interface itself could be only some 1:1 wiring?
            Beppo
