Long shot but worth asking
  • Long shot but worth asking
    hi guys
    i've jsut finished my fabrication project, this involved making my lilliput look factory fitted into the car, i done this by simply buyiong a spare ashtray/sunglass holder, cutting a massive hole in it and slotting the screen in (fully cased) then using bondo type filler then sand and spray.
    The dam thing now does not Power On, i havent opened it or anyhting like that, screen and buttons were fully covered prior to sandaing and spraying.
    Any idea's guys.
    thanks
    [SIZE=6]Join Date: Aug 2003
    Vehicle: 2004 320d Sport Touring
    HP-Epc, 512mb Ram, 250gb hd, Lilliput, GPS.
    [/SIZE]
    Make sure your power cord isn't the culprit. My dc adaptor just gave up two days after use and the ac adaptor didn't work out of the box. I returned both and and have had no problems since.
    ________________
    ______ILL.1______
      hi mate,
      i've tried both the car nad home ac connectorts,
      [/SIZE]
        dust inside on/off switch?
          will be brekaing it apart tonight, what a sham, looks really good for my first job
          [/SIZE]
            Note for next time: "Remember to fabricate it so the electronics are still accessible without damaging fab job!" Lots of people here leave the back off their lilliputs & xenarcs when they fab them into the dash, I think, so that they can pull the dash piece off and get at the guts of the screen without messing up their sanding.
            Chrysler 300 - Fabricating
            http://hallert.net/
              To do a proper fabrication job you need to use paint and water...even the best "sealing" of the screen will still allow dust, paint and water to get into the screen.
              You've (probably) ****ed the internals
              Garry
              Co-Developer of A.I.M.E.E
              www.aimee.cc
                Check the power going to the screen.. check your cars power make sure there's voltage getting to the screen...
                Didnt read all the posts this might have been said already..
                I really hope you get that worked out, I just finished my in-dash FAB.. I hope my screen powers up...
                I fab'd the front of a xenarc into the dash with the back and guts kept completely seperate (away from the paint,dust and water)
                Progress [I will seriously never be done!]
                Via EPIA MII
                512MB RAM
                OEM GPS (embedded)
                nLite WinXP pro on
                1GB Extreme III CF card
                Carnetix 1260 startup/ DC-DC regulator
                Software: Still, re-Writing my existing front end in .Net
                  i think so, o well, will smash it open tonight, if fails will start the search for a new screen.
                  Thanks for all the ideas everyone.
                  Garry
                  [/SIZE]
                    Goodnews,
                    i thought i'd try it again just now and it turned on, wicked, same me some money, butttt, none of the buttons except the Power buttons work, it a lot of work for me to open it up so i wanted to know if i could cover all the buttons up and just use the remote control, anyonw know where the sensor for it is.
                    cheers
                    [/SIZE]
                      use the remote thats all i have anyway the sensor is centralised
                      Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
                        Just tried it, dont work, looks like all the buttons and the little sensor in the middle are fuxked.
                        [/SIZE]
                          Guys, please some more help please :
                          so far :
                          1, The screen has an intermediate problem, some times it turns on and some times it don't.
                          2, Only the Power light works (blue'ish)
                          3, The remote does not work.
                          Question's,
                          I have open the screen up now to see the condition of the inside, and before you ask yes there was a lot of dust.
                          As i have a intermidiate on/off problem is there a paticular cable i should be checking?
                          What can i doo to get the remote / lights working ?
                          Is there anyone in the UK who can supply spare's
                          [/SIZE]
                            hOLLY CRAP,
                            I Opened it all up again and re conected everything agian, put it all back together, and i dont know how but every thing works again, thanks to all here for the support.
                            Roger
                            [/SIZE]
                              those ribbons are really touchy, i have same problems whenever i take apart my screen
