usb plug defective?
  • usb plug defective?
    every time I plug the touchscreen usb cable to the pc my system finds SIX new pieces of hardware, and none of them takes the right driver, they remains "unknown devices" and no way to make touchscreen work. I think my unit is defective, I tried to open it and clean each ribbon connection with no luck, any last idea before returning it for RMA? I really don't like the idea
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    prob not the plug... probably the internal usb stuff in your ts... do you use any other usb stuff that works?
    Kimi ga kawareba, Seikaimo kawaru!
      Did you install the driver first?
      Installed the driver, then plugin the USB TS.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        might be a USB 2.0 controller and all that stuff it's finding is the USB controller.
        肚子笑痛了
        S60 Install
          I use several usb pheriperals with no probs
          I tried on usb 1.x and 2.0, same problem
          I tried on several systems, one time in the exatc istant when I plugged the usb, the computer PSU got fried
          Peugeot 206 1.4 HDi
          Celeron 1.2ghz
          256mb DDR-2 533
          80gig 3.5" SATA HDD
          M2-ATX
          8" Lilliput TS LCD
            What TS are you using? If its a Lilliput, add another problem to the list. Also, try the new drivers, I've had problems where Windows thought the INF files were corrupted.
            Quick! To the Popemobile!
              Yes it's a lilliput but I don't thint it's a software issue, on another machine with usb1.x I haven't been able to make my touch recognizer, I plug the usb connector and nothing happens
              I'm gonna take an RMA for it, I hope it is a 2 years warranty
              Peugeot 206 1.4 HDi
              Celeron 1.2ghz
              256mb DDR-2 533
              80gig 3.5" SATA HDD
              M2-ATX
              8" Lilliput TS LCD
