Possible solution for people with screen interference (Pics)
  • Possible solution for people with screen interference (Pics)
    After having probs with my xenarc/gain and getting ignition noise on it i decided to try and figure out what it was. Well i am using a DC-DC convertor which is supposed to ensure a regulated 12v feed. Well , it may be regulated but certainly not clean. Many people said they used their opuses for the feed and all is well. I tried this and it seemed to sort the noise (hortixoltal lines on it) and also the fadeing when i started the car. Well through my days of car audio i had accumilated a 'Shark Noise Power Filter' which actually cleans the power going to the 12v line. I bought this from maplin.co.uk once in a vain attempt to fix some alternator whine which in the end was some annoying ground loop. SO i thought id give it a try. My results were suprising. All of the visual noise lines etc had gone. Didnt seem to fix the dimming when i started which is surprising as the opus as a circuit designed to store current when the car is started so voltage doesnt drop but all the noise has gone.
    Heres a pic of it: -
    And here is a pic of its guts: -
    Anyone know whats in it and why it seems to work so well?
    Ill keep using it and let you know how it goes but early impressions are very good.
    Jamie
    Most noise suppressors are just an inductor (the big thing with the blue tape in the picture above) and a capacitor. These two components form a filter to attenuate a range of frequencies that cause undesired results in electronic equipment.
    TGIF!!!!
      Where can I find one? And how much is it? I've had noise on my screen but just gotten used to it....
      CarPC install is starting to come along again...
        You might look at these:
        http://pac-audio.com/products/passivefilters.htm
        Not sure if they're exactly what you're looking for, but I'm guessing someone around here can confirm or deny.
        '03 Sierra Denali
          yea its just an inductor that filters out the noise
            Jamie
            Looks like a fancy version of an in line noise suppressor kit I purchased at radio shack. Just mounted on a board. Mine worked great at eliminating noise and interferance.
              This is where i bought it.
              Here is my one i found : -
              http://www.maplin.co.uk/Module.aspx?...ldID=&doy=3m12
              This is another one also which i havent tried but it seems the same
              J
                My 60 dollar screen from digitalww came with one of those... i popped it open too and found a fuse as well.
                  Rat Shack or Wall wart have it.
                    haha
                    [ 5-spd 1996 M A X i M A SE ]
                      Can someone link me to one of these on Radioshack's website?
                        10 Amp, Enough for ANY screen.
                        http://www.radioshack.com/product.as...D051&hp=search
                        20 Amp Heavy Duty
                        http://www.radioshack.com/product.as...55&site=search
                          Thanks.
                            Anyone have a link on radioshack to this product? I tried the 2 links above and they are dead. Thanks
                              Sniffle No one? This is the last item holding me up in my car pc install is the darn interferance on the screen so any help getting those part numbers would be awesome.
