Lilliput 7" @ 800x480
  • Lilliput 7" @ 800x480
    I'm using powerstrip to run my Lilliput at 800x480 (native resolution). Everything is fine except the image displays on the top portion of the screen. Across the bottom 1/4 or so its just all black. If i go back to 800x600 it fills the rest of the screen. I'm guessing its something simple i'm missing
    Thanks!
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
    Is there an auto-adjust or similar feature you could try?
    BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
      Yeah, i tried the auto adjust as well as turning the lcd off and back on. Unplugging power etc. I haven't tried doing a software reset (via controls) yet, however will try that in the morning. Doubt that will work though.
      any other suggestions?
      thanks
      7" Lilliput LCD
        Are you able to get a 800X480 resolution so that even the Lilliput screen think it's running that resolution ? If so, would you mind posting your settings ?
        Now, your problem, I made a software reset on mine before I did the adjustments in Powerstrip and it fills up the whole screen, looks allright too
        although the Lilliput thinks it's running 640X480. (or maybe it was 640X400, I'm re-installing XP right now so I'll have to check later)
        /M
          hmmm, i'll try that right now. The software reset did nothing...and i just noticed there is a black strip along the top too. it thinks its running 800x600 right now. I'll go try and repost
          7" Lilliput LCD
            640x480 fills the screen...but i cannot get 800x480 to. It just puts the display to the top of the screen. What should my refresh settings be? And would that make a difference?
            7" Lilliput LCD
              This is what I'm using...
              PowerStrip timing parameters:
              800x480=800,68,80,52,480,47,3,33,34063,278
              Generic timing details for 800x480:
              HFP=68 HSW=80 HBP=52 kHz=34 VFP=47 VSW=3 VBP=33 Hz=61
              Linux modeline parameters:
              "800x480" 34.063 800 868 948 1000 480 527 530 563 -hsync -vsync
