Moving Lilliput Infrared Reciever...
  • Moving Lilliput Infrared Reciever...
    Is there anyway to wire the Lilliput 7" TS to extend the infrared reciever? Just don't know if I can use standard wire/solder or not. Thanks.
    2004 WRX Carputer
    I know there's a post around here somewhere by Altimat (IIRC) about relocating the buttons, probably IR receiver as well? I'm sure the is your friend...
      Did do a search... found that thread, but wasn't exactly what I needed...
      2004 WRX Carputer
        Yes, unsolder the IR receiver from the button board (3 pins) and then use small-gauge wire to extend the sensor to where ever you want it to be.
        89 Supra Turbo
          Do I need a special soldering iron to get a solder that small?
          2004 WRX Carputer
            The IR reciever isn't that small. A standard cheapo soldering iron from Radioshack should work just fine. I extended mine with an extra CDROM/Audio cable.
            2004 4runner
              Edit: Nevermind, answered my own question.
              2004 WRX Carputer
                I asked this in another thread, but this was more along the lines of what I was looking for.....the plastic in front of the IR eye, is that special plastic? Or should I just put the IR eye behind one of the vents in my car?
                Molded Screen:
                [++++++----] 60%
                DVD & Rest of audio:
                [++++++----] 60%
                2004 Accord Coupe, Satin Silver K24 5 Speed powa!
                7" Lilliput Screen, non touch with lots of Bondo
                NTB DVD player or put XBOX in car
                My 04 Accord Picture Thread
