Can´t calibrate lilliput 100%
  • Can´t calibrate lilliput 100%
    Im using touchkit for lilliput 7", after pressing 25 cirkels on my screen in advance mode it still not working 100%. Anynone in here know what to do?
    It worked until i pressed auto setup on lilliput....
    P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
    you might need to buy the new touch overlay from digitalww.com or usually the right side of the screen with go off due to overheating.
    PC Components:
    My work log
      What? Have problem in right side, so i have to send it back? Still have garantie.
        Anyone have the same problem? Help please!!!!
          Many here have the same problem ....
          maybe one day there will be a fix for it.
          I personally have (3) that are bad.
            Sounds like a dead touchscreen
            PowerVoice v1 | NaviVoice Source
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              So..can i get a new at garantie? Its only ˝year old.
                Depends if its still under warranty. But if you send it back, there is still a high chance that it will break. Get a good touchscreen from http://www.digitalww.com
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
