lilliput dodgy touchscreen?
  • lilliput dodgy touchscreen?
    Hi Guys....
    I have had my Lilliput touchscreen for about two-three months. Has been working no problem.
    Last weekend...I was trying to get phonecontrol to work on my VanPc. It was cold…so I had the heater on in the van….and suddenly…I started having problems trying to click on the right hand side of the screen…
    I thought it may be heat related….
    Yesterday….again it was cold….and I tested the screen…same problem…even when the van was cold…
    Its not in the extreme corners…it is up about an inch from the bottom of the screen…doing a draw test proves this.
    I know a lot has been written on these forums about the Lilliput…but the problems that guys have been writing to this forum seem to have dried up about 6 months ago….
    I just wondered if someone with experience could tell me if this screen needs to go back?…
    Is it is a faulty screen?……or could it be to do with me loading and reloading widcomm drivers?
    Any help will be appreciated…
    vintageb3
    M10000 mainboard,256 RAM, 80 Gig 3.5" drive, PWS-120-M, ITPS, Lilliput 7" touchscreen, XP Pro SP2, Frodoplayer, Map Monkey, InfoMap Navigator 4, WIFI
    Current: Bluetooth. Trying to get Phonecontrol to work with SE T610.
    It's not the screen itself it is your touch overlay. I am actually waiting for my second replacement overlay right now. Contact Armen over @ www.digitalww.com
      The touchscreen overlays on Lilliputs are pretty much crap. It is especially common for them to have difficulties on the right side of the screen. Mine has a similar problem to yours in that it is ok in the corners but as I go toward the middle of the screen on the right side, it becomes quite far off.
        So...Should I cut to the chase and just buy a overlay?...or send it back?
        I mean...if the Lilliput overlay is crap...why bother letting them replace it...
        OR should I just ditch this...and buy something else?
        hmmm
        vintageb3
          OK..so what I need to know is....are these absolute crap?...is it worth spending more money on?
          This screen has already cost my £200.00 (well just under)
          bummer!
          vintageb3
            To clarify...Is this the second overlay from Armen?
            vintageb3
              If you can get your replaced under warranty then that’s what you should do.
              If you buy a panel from me it still might go bad but I will replace it under warranty.
              Armen
              hmmm
              vintageb3
              http://www.digitalww.com
                Armen
                Hi Armen....
                Just emailed you...
                vintageb3
