Voyager-systems LCD Pinout
  • Voyager-systems LCD Pinout
    I have picked up one of the following screens
    Voyager-systems TFT LCD
    Model PML2004 5.6 LCD Monitor
    Display method TFT active matrix, RGB colour stripe
    Resolution Horizontal (H): 960 x Vertical (V): 234 dot (224640)
    Active area (mm) 105 x 87, diagonally
    Viewing angle Horizontal: 90 degree, Vertical: 40 degree
    Pixel pitch (mm) Horizontal: 0.414 x Vertical: 0.416
    Displayable colours Full
    Brightness (typical) 280 nits
    Contrast ratio (typical) 120:1
    Video input signal Composite A/V (1Vpp) 75 Ohms
    Video output signal Composite A/V (1Vpp) 75 Ohms
    Signal connection 3.5mm Jack. (Some have Mini 8 pin DIN pigtail also)
    Power supply 12Vdc nominal
    I have two output cables for this.
    A jackplug and power jack (screen end)to an 8 pin mini-din socket.
    The other is a 8pin mini-din female (pigtail end)to an 8pin full sized din plug.
    From the looks of it I can also reverse the first cable and put it on the pigtail leaving me a normal power type plug and a 3.5mm stereo style plug for video/audio in.
    My question is anybody know if this will connect to an epia board. If so whats the pinout for an epia s-video or do I use rca? I have searched for S-video pinout but only one usefull thread giving me a pinout for 4 pin din 1 and 2 earth 3 luminance 4 chrominance
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
