Why does my Lilliput 8" screen role during startup, & only in startup? Please help
  • Why does my Lilliput 8" screen role during startup, & only in startup? Please help
    I hook computer up inside and there is no problem. Plus I have used two different PC's, and there has been the same problem. while the computer is starting up, the screen roles, all the way until windows start and then its fine. It even roles while the Windows XP logo is showing telling you it is opening up and I don't know why. I would love some help, it looks like crap.
    thanks,
    Kenny
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
    I have no idea what is causing it, but until you find a solution, you can avoid seeing the Windows XP loading screen if you are using XP SP2.
    Run the System Configuration Utility (msconfig), go to BOOT.INI tab and select NOGUIBOOT.
    Why don't send an email to you supplier, see if you can send it back (RMA).
    - CarPC: Lilliput 7" Touchscreen, VIA EPIA M10000, 512 MB, 40 GB HDD
    - Install: 90%
      Is it VGA or Composite??
        roll <-> role
        role (rōl)
        n.
        also rôle
        * A character or part played by a performer.
        * The characteristic and expected social behavior of an individual.
        * A function or position. See synonyms at function.
        * Linguistics. The function of a word or construction, as in a sentence.
        roll (rōl)
        v., rolled, roll·ing, rolls.
        v.intr.
        * To move forward along a surface by revolving on an axis or by repeatedly turning over.
        * To travel or be moved on wheels or rollers: rolled down the sidewalk on their scooters.
        * To travel around; wander: roll from town to town.
        * To travel or be carried in a vehicle.
        * To be carried on a stream: The logs rolled down the cascading river.
        * To start to move or operate: The press wouldn't roll.
        * To work or succeed in a sustained way; gain momentum: The political campaign finally began to roll.
        * To go by; elapse: The days rolled along.
        * To recur. Often used with around: Summer has rolled around again.
        * To move in a periodic revolution, as a planet in its orbit.
        * To turn over and over: The puppy rolled in the mud.
        * To shift the gaze usually quickly and continually: The child's eyes rolled with fright.
        * To turn around or revolve on or as if on an axis.
        * To move or advance with a rising and falling motion; undulate: The waves rolled toward shore.
        * To extend or appear to extend in gentle rises and falls: The dunes roll to the sea.
        * To move or rock from side to side: The ship pitched and rolled in heavy seas.
        * To walk with a swaying, unsteady motion.
        * To take the shape of a ball or cylinder: Yarn rolls easily.
        * To become flattened by or as if by pressure applied by a roller.
        * To make a deep, prolonged, surging sound: Thunder rolled in the distance.
        * To make a sustained trilling sound, as certain birds do.
        * To beat a drum in a continuous series of short blows.
        * To pour or flow in or as if in a continual stream: tourists rolling into the city.
        * To enjoy ample amounts: rolled in the money.
        As to your problem, sounds to me like the 12 volt power is getting pulled down too far on start, get a bigger battery?
          I know its not the power, because I have had it powered by three different sources. The original egg, the first power supply I used, which was 400 watts, and now the M1-ATX. I am using VGA, let me know if I can switch to a composite, and I might try it. I set the bios to CRT screen, and thought that might help, I might try some other configurations. Its just strange that it only does it when running the check at system start up, and when it says
          "windows starting" I think, not after windows opens.
          Hmm, see your point, it was a 3 in the morning after being frustrated by installing everything, and then one of the files in my sound blaster got corrupted, and I don't have a freakin CD player to run a reinstall. It would definitely be "roll"
          thanks for the help,
          K
          Edit:
          It also did it when I had the computer in the house with the screen right next to it, and the VGA cable was a few feet long. But not when I used a normal size screen.
            I got rid of the scrolling when I boot after I changed my boot logo. I ended up using the program at http://www.belchfire.net/~userxp/indexbe.htm that saved my a**. I jacked up the computer and couldn't logon after I did the supposed simple way. But this program adds a kernel I believe to boot.ini. Somehow it fixed the scrolling for that point allthough I still get in bios. But hey, better then nothing. If you want to change your boot logo screen in xp, I highly recommened using that software, its simple, plus it gives you two boot options when you restart in case there is a problem, but it won't let you screw up.
            later
              Man, I was having the problem with the screen rolling during startup. I changed the bios to CRT+LCD, and it fixed the boot screen from rolling, and the hibernating screen which rolled as well, plus the first screen that tells you to hit delete from rolling. But, the bios screens that did not roll before, the ones between the first bios screen and the boot graphic, are now white lines. What the hell. Now if I try to go to the bios after selecting CRT+LCD, it is a black screen with a white line, so I can't tell what the hell is going on to change anything. It doesn't make any damn sense to me. I dont' know which way I like better. It wouldn't be that bad, but the bios screens right before the boot logo are all white lines that aren't steady. Has this crap happened to anyone else, or is it just me. Its driving up the freaking wall, I don't know if its the M10000 or the 8" lilliput, or just some other option in the bios setting that I am missing. I can plug a normal monitor into the computer right now and get the bios screen just fine. If anyone has any ideas, settings in bios, please let me know.
              thanks,
              Kenny
