Just got the 8" Lilliput (809GL-80NP)
  • Just got the 8" Lilliput (809GL-80NP)
    8" TFT w/ touchscreen, it's farkin awesome. Everything connects through one port! RCA/Svideo in, vga/usb out, dc-in, it all goes through this one easy plug. Well worth the cash.
    -w
    P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
    I am thinking about getting this screen and am in the market for an extra shroud. how is the detail on the screen? do you like it? any downs to this model? where did you buy this at. If you want to put how much you paid for it I would appreciate it but I understand thats a personal question and you dont have to answer. ;-)
      If you get the drivers listed in the lilliput forum, just reboot after plugging it in and then install the drivers. The quality is pretty good, I had it connected to my Radeon 9800AIW, so it wouldnt do anything lower than 800x600 or between 8x6 and 1024x768. The fact that all the connectors go through one port located on the bottom of the unit is fantastic, I am building a slide bracker to mount the lcd in for quick removal, and this just makes it 10x easier. I probably need to turn on themes and get some better fonts, I don't use themes on my desktop for optimization reasons and consequently the text was a little blurry. Not unreadable, just a little blurry. Also, I've found that if you push on the back of the unit (lightly) above the input port and speaker, the text gets really shakey, like a small shielding issue. But as long as you dont push on it you're fine. The touchscreen was way off when I first connected it, but after the linearization and calibration it tracks like a dream.
      One more thing, the video input autoselects the vga port now, I think I read somewhere that on the smaller/older versions it didn't.
      Any other questions?
      -w
        Awsome! Thanx bud. Do you know if anyone makes a extra case so I can mold it in my dash?
          I think I've seen them around, not sure where, here maybe?
          I just tried 1024x768 and it seems actually a bit clearer than 800x600, text is smaller, but not as blurry, I don't know if that makes sense.
          -w
            Have you tried using Powerstrip and 640X480. I believe that would give you one-to-one pixel mapping and the clearest immage.
              This display's default resolution is 800x600.
              PowerVoice v1 | NaviVoice Source
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                -w
                Have you tried hooking anything up to the RCA inputs?
                I can't get my 8" to recognize an NTSC source.
                  if I power up a svideo camera will it auto detect? and then go back to vga?
                  backup light on camera on video is switched then when I put it in drive it goes back to vga
                  hopefully it does this
                  2005 Ford Mustang GT <- - - UPDATED PICTURES
                  2003 KAWASAKI Z1000 - CUSTOM MODZ
                  MBK (AIM = IllMBKllI)
                    What are the case dimensions of the new 8"... Im thinking of changing my 7 to an 8?!? If one will fit in my dash!
                    My Nissan 200SX @ Silverstone
                    NOW SADLY WRITTEN OFF!
                    My Car's spec list + pics
                    Stealth CarPC fab'ing...
                      I also am wondering what the LCD/case dimensions are. I'm not sure if it will fit, even with hacking my dash. Does anyone have measurements? If so, Thanks in advance!
                      WORKLOG
                      Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
                      Webpage
                        from the site
                        -Monitor: Height 6 3/8" (162mm) x Width 8 1/16"(204mm) x Depth 1 1/2" (39mm)
                        -LCD Panel: Height 5 1/2" (141mm) x Width 7 3/16"(183mm) x Depth 1/2" (14mm)
                        http://www.digitalww.com/VGA_TM_810VGT.htm
                          armen also sells the project housings..
                          http://www.digitalww.com/lilliput_housing_8.htm
                          rebuilding carpc... kinda..
                            Originally posted by mgars
                            from the digitalww site
                            Awesome! you guys rock!
                            Now to see if it will fit....
                            WORKLOG
                            Webpage
                              Can anyone confirm if the function to mirror video works on this model? If so, does it need to be reset each time the monitor is turned on, or does it retain the settings? Does it just flip the selected video input or all of them?
                              I need a monitor that flips the x-axis for a backup camera (which is just a normal camera, not the revere image kind).
                              "Protecting Privacy and Free Speech Online"
                              http://www.eff.org/
