vga cable for lilliput
  • vga cable for lilliput
    Ok so like most of us, my lilli cannon plug connector was a problem from day 1. my touchscreen wouldnt work from the very beginning without messing with and pinching the connector the entire time,then i started getting the jurassic screen of death and a complete white out.
    So I decided to swap out the cannon plug for a regular vga cable. problem is I had a brainfart and grabbed a regual 15 pin vga M-F extension , cut it in half, clipped my cannon plug off the lilli and then realized I should have gotten a 9 pin cable. so I went to find a 9 pin cable locally and had no luck.
    I'm sure I can use the vga cable I have but i'm not sure of the wire connections.
    anyone have some kind of diagram of the wire/pin connections from the lill cable to a standard vga cable?
    thanks for the help
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    problem was i was thinking about it a little too in depth. I was having issues with which color to which pin from the vga card connection. researched a little more and found the wire connection and usb diagrams. i think i got it all under control now
    josh I think you misunderstood what i was saying, i cut just the cannon plug off the cable comming from the lilliput. i didnt open it up and totally remove the cable, which i think i may just do anyway.
    Oh and as for your sig...nice landings are directly proportional to the ratio of golden beads x the pucker factor
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
