Successful Dual Video outs
  • Successful Dual Video outs
    Ive been searching on this topic quite a bit lately
    Alot of projects always start out saying " I want 2 screens one with video and one with gps" and so on but not many ppl come back to say "hey i got it working!"
    what im wondering is cpu usage wise, power consumption, and specs wise
    if you have dual video outs on your system
    **NOT CLONED VIDEO BUT 2 TOTALLY DIFFERENT DISPLAYS (NVIEW)**
    what type of setup do you have
    is your system stable
    is the opus or your psu supporting your setup
    has anyone mastered this basically
    My main thing is epia is appealing but looks like video will be choppy if it can be done at all, HOWEVER then its a constant battle over power consumption and the inevitable "will the opus power this" thread.
    BTW ive done power consumption calculators but i get diff number on diff calculators
    SO if you have a functioning dual vid out system if you could post your specs and even trials and errors you went thru i think it would help out a bunch
    *im not looking for ppl to do the research for me i am planning an Asus A7N8X-VM and Mobile Athlon 2500+ system but im also confused on whether i need to put a second Geforce vid card, any housebrand vid card or if one of these or these will work*
    -Lost reception
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    well at home i have 3 LCDs 2 vid cards You just set it as dual veiw and then you can have apps open in the A B C screen, i recomend a GeForce card. Or just get a shuttle barebones and if its the right one you will have dual VGA.
    Just get a Video card with dual heads and it should work.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
      the Asus A7N8X-VM supports Nview apparently
      From the Asus Spec Page
      _____________________________
      VGA -Integrated GeForce4 MX GPU
      -Integrated TV encoder
      -NVIDA nVIEW dual-display architecture
      -Support DVI (AGP-NV-DVI) and TV out (AV/S) cards
      I think thats confusing me a little
      the board only has from what i can see only has one vga out
      whats required for a second display one of the things i posted previously or a second gforce OR just a vid card
      i know this can be done i was just hoping to see some ppls working examples and get some feedback
      .______
      | '_ |__\___
      [(o)|___(o)] XB
      ._________
      | I__I I_I|_\__I
      CarPCNetwork
        the dual head is only fromt he VGA and tV out. There is only one nForce2 IGP mATX board wheich has dual VGA out supporting nview and that is an Epox model.
        The only ways you could do it are
        a: run a VGA and svideo/rca screen
        b: put a PCI graphics card in and run both - but this is always crappy
        c: buy a dual head AGP card and disable the onboard graphics - easiest option
        d: buy the Epox!
          http://www.newegg.com/app/viewProduc...123-216&depa=1
            hey thats a good deal...
            1990 Jeep Cherokee
              it is a consideration ive made but i dont like losing my serial port ive heard the USB replicators sometimes dont work properly. otherwise its a great board
              .______
              | '_ |__\___
              [(o)|___(o)] XB
              ._________
              | I__I I_I|_\__I
              CarPCNetwork
                hold up a second, possible correction from above correct me if im wrong because if im not this seems to be the perfect board (for me)
                I read on the specs page
                ___________
                I/O CONNECTOR:
                PS/2 Mouse and PS/2 style Keyboard Printer, Audio-in/out, MIC connectors COM1, COM2, Game Port by extra Cable
                _________________
                scouse i saw a post on here this was your concern as well
                If I am reading the right specs it seems i can add just a cable and be done ?
                EDIT again
                someone on newegg said "I wish it supported clock multipliers because then you could use Mobile Athlons. Other than that, solid board."
                does the wire trick solve this or no im not much of an overclocker...
                .______
                | '_ |__\___
                [(o)|___(o)] XB
                ._________
                | I__I I_I|_\__I
                CarPCNetwork
                  I dont know how they do it, I heard that they had custom hardware from manufacturer and their mobo manufacturer...plus there is tons of programming, but I cant wait
                  http://www.digitalicetechnology.com/dss.html
                  I guess someone is already on it.
                  Noobiiiii
                  with much knowledge!
                  50% completed demo car for Dice, Inc.
                    yea i talked to the owner of that company one day and it sounds cool...
                    1990 Jeep Cherokee
                      Lostreception, most boards have an on-board serial header, as they have 2 serial ports - i guess they just used 2 serial headers as they used the space for a VGA out. As for the wire trick it should be ok. The Asus you wre looking at has to do the wire trick and the wire trick is done so the CPU apprears like a normal athlon CPU so the mobo should not know the difference. The epox may have adjustable FSB so that would be 1 less set of wires you would have to do.
                      Actually, just read this fromthose specs you posted:
                      CPU Vcore, Clock and Multiplier setting via BIOS Supports AGP Vcore setting via BIOS Supports Memory Voltage setting via BIOS.
                      But i am not sure if they all have firewire - it says it can but a lot of specs have the options on that are not used.
                      I think i might get this board but i don't know where from in the UK! dammit!
                      As for Dice, the guys are members on here. On guys name starts yunsu... or summit i think
                      EDIT: setting by bos might mean that it doe sit automatically from the CPU ID stuff - what the wire trick replicates. YOu really awant to set the vcore as low as possible to save power
                        So w/ this "cable" i can or cannot add a serial port as far a you know.
                        ___also to get back on track
                        Does anyone have a successful 2 output setup VGA or Composite/Svid they would like to share with us
                        based on one signal will only be for gps and or computer based speedometer/gagues vga isnt really neccissarry
                        .______
                        | '_ |__\___
                        [(o)|___(o)] XB
                        ._________
                        | I__I I_I|_\__I
                        CarPCNetwork
                          I am getting close to doing this to.
                          I have an epia m10k board and want to add this card. It should do the trick.
                          I was thinking about running one of the softwares that allows two people to work on the same computer running different application with different keyboards/video/mouse.
                            The serial ports will be via a header which has one or two 9 pin serial conenctors on it - like a USB header.
                            I have used a 3 monitor setup on my desktop by adding a PCI card to my normal duyal head radeon. It caused a lot of trouble adding an old PCI card - i don't recommend doing it that way. easiest way by far is to use 1 video card with dual outputs.
                              My shuttle has nforce, and has 2 vga out puts! Shuttle SN41G2
                              1992 z71 Chevy
