Lilliput hell
  • Lilliput hell
    After looking at some of the custom installs i decided to give it a go myself.
    i think i did a semi decent job but ended up with a white screen.
    so i sereched the forums and found that the common problem is the 40 pin ribbon
    I then managed to blow the small 1 amp fuse, but managed to replace it(soldered a 1 Amp fuse fire across it).
    After waiting for almost three weeks i got the ribbon cables from digitalww but odered the wrong ones. so i redodered the right ones and got them with-in a week (thanks armen).
    Still no luck with the white screen. after spending about three hours trying to reseat the damm cable i thinks its capoot. so if no ones got any ideas any one intrested in a possible fried lilliput or any one out there with some lilliput spares??????
    Lilitput 7" touch screen :-( , Epia -M 256ddr, Opus150w,
    I have a TView and I had a similar issue.. with mine when I start the truck it turned white instantly.. even when the power buttons was not on.. however if I connected the vga cable to my PC it would work normal..
    something happened with my ground, so I connected my vga ground and auto ground line together.. works fine now.
    so maybe that will help
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
      I havent connected the lilliput back to the pc yet becuase of the white screen. if the lillput is not connected to anything it should normally say no signal on a black screen shoudent it.
        yes.. my screen did the same as yours .. try grounding the VGA cable.. just touch the housing to a ground source.. that should do it..
        -shawn
        Shawn
          :-( no luck . any other ideas out there??
            bummer.. you could try connecting it to your board.. but do that at your own risk ..
            of course I fried 3 PSu's so far.. so .. well yeah..
            the problem seems so similar.. don't lilliputs have a warrenty?..
            Shawn
              gose out of the window the moment you start gutting it, respraying it , bonding it with your dash , then again theres probably no harm in asking is there?????
              I got mine form ebay posted from hong kong. i dont think it would be worth my time chasing the guy and trying to expalin what ive done as his english is very limited (a lot worser than mine).
              i think im having a really **** week. i just recived a DVD/VCD/MP3 etc player this morning which was supposed to have Aux in (180 uk / almost $300 and its of ebay again) ive just emailed the guy expalining what aux in actually is and hes telling me to take to a professional. thank the lord for paypal! haa haa haa
              so any one with a cheap lilliput out there????
                it's got to be something simple.
                sometimes if I just take something like this apart .. and look it over.. I'll see a loose connection or a burned out component.. ya know..
                I wish I knew more about electronics other wise I'd buy it from ya and fix it..
                Shawn
                  I had the same problem. I figgited with trying to reseat the stupid thing for like 45 minutes, before I finally got it. The screen will display one of the following:
                  All white if the ribbon is not pluged in at all
                  Black w/ "no vga" or fuzzy black if the ribbon is seated improperly
                  good picture if properly seated.
                  The only way I found to seat it was to plug into the wall and plug into my spare PC and fidget til I got a desktop. Now, while taking it apart I screwed up the ribbons so I have to order those. AHHHHH.
                  Its not the cards you're dealt, its how you play the hand!
                  Originally posted by ryuandwings
                  Where can I get a roll of tin foil?
                  I been looking for that all over the net, but I can't find it.
                  Please help.
                    with some soldering and rainbow ribon wire.. you should be able to nix a broken ribbon .. but I'm cheap
                    Shawn
                      This suggests he could just have the cable "upside down" in the connector(s). I think the conductors are only presented on one side of the cable end, so if you flip it over it might as well not be connected...
                      SeeYa! -Jim-
                        tried all possible ways of connectiong it with the ribion cable, dont even get any fuzy lines, stripes or any thing else . how would i know if ive blown the vga card???
                          Any particular way you got the ribbon cable faster from DigitalWW the second time, I don't wanna wait 3 weeks. Also, anyone know, besides used, where I might be able to buy the part that the cable connects to on the screen, I tried emailing Lillput but i got MailerDemon!
                          Please help.
                            just say please.
                              Don't have a Lilliput, but had same problem with my no-name screen.
                              With mine, it seems to be a problem of turning the screen on after the computer is on, or before. If screen on before, then no problem, if screen on after the computer, then I get a white screen. Haven't installed in car yet, so don't know how it will do when hooked up to the PSU on the computer.
                              C134 Case
                              VIA EPIA M10000
                              FrodoPlayer
                              iGuidance + GPS
                              7" touchscreen LCD
                              2000 Mitsubishi Eclipse GT
                              - V6 216hp
                              - KYB-AGX adjustable struts
                              - Konei Alloy 17" rims + Pirelli P-Zero's
                              - AEM slotted brakes
                              - AEM CAI
