is there hope?
  • is there hope?
    So now I managed to totally hose myself with my lilliput. Took it apart to solder a new vga and usb cable on it because the 9pin connector was a POS since the day I got it, it wouldnt even pick up the usb signal inless you jammed the connectors together and then put pressure on the connector area.
    anyway, in the process of soldering I managed to bump the side of the soldering iron against the smaller ribbon cable and warped a few of the pins, tried to flatten it out and reseat it a couple dozen times to no avail.
    so someone suggested i check the link on digitalww for installing the in dash housing and change the cable connection to wires. After trying to solder the microscopic connections I got the brillant idea to pop off the white connector clip so i had a better area to work with. Bad Idea, the clip came off alright,along with most of the pins. Needless to say I was ****ed off. in 99% of all cases when its electronic related I can fix it, leave it to me to f up this one thing. I should have just sent it back to mp3car when i got it and the connector was a problem but I sent an e-mail about it and never got a response. so I figured I was just SOL
    my guess is I'm pretty much screwed here or is there any hope of fixing this thing? i did dro an e-mail to the lilliput office in cali but havent heard back from em yet, someone posted the website and said they got thier lilli repaired for like $30 plus shipping
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    that realy sucks man. i fell your pain. there must be a place out there were you can just buy the vga card only as that the most likley thing us suckers are going to screw up.
    Lilitput 7" touch screen :-( , Epia -M 256ddr, Opus150w,
      what sucks is, the reason we have to take em apart and screw em up in the first place is that the manufacturer builds a complete POS.
      sent an e-mail the other day to http://www.lilliputweb.net/
      Lilliput Electronics (USA) Inc.
      5100 Walnut Grove Ave., #C
      San Gabriel. CA 91776, USA
      Tel: 626-286-4828 Fax: 626-286-4798
      to see about having it repaired. no reply from them yet but i'll let ya know if i ever get any info
      2003 PT Cruiser
      Freakville Pc's
      The PT Crew
      my cardomain page
      my webshots page
        pic of damaged area
        theres a pic of the clip area
        2003 PT Cruiser
        Freakville Pc's
        The PT Crew
        my cardomain page
        my webshots page
