Dynamix 706 dimensions
  • Dynamix 706 dimensions
    Hey guys, I've been looking everywhere for this and had to contact Dynamix in order to get it. It may be very helpful to some of you planning on using their monitor.
    Monitor Dimensions: Dynamix 706 173L x 115H x 29W mm
    Monitor Dimensions: Dynamix 705 180L x 135H x 29W mm
    Monitor Dimensions: Dynamix 805 220L x 163H x 37W mm
    Not really... I haven't seen the T-View or Innovatek ones that have the same specs as the new Dynamix ones. The old Dynamix models are the same, but the new ones are definitely improved so the guts must be different, just the casing is the same but with a different logo.
    For example, the new Dynamix 706 has a Brightness Rating of 400cd/mē where all of the other 7" models have 250 (other than the more expensive ones like Lilliput and Xenarc)
      if you are looking at ebay postings of dynamix screens, i would NOT take the listed specs as being 100 percent fact. Some of the listings i have seen were a listing of the 805 (an 8" 4:3 screen ) under the title of the 706 (7" widescreen)
      if they can make such large mistakes in even listing the correct model numbers, how can you be sure the specs are right? i would get a Tview or a linITX from a more reputable seller.
      System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
      Progress: Installation: 90% Dash fabrication: 80%
      Parts Needed: USB GPS
        can anyone confirm that the 706 is the same as the linitx screens?
          anyone?
