Lilliput Touchscreen Connection problems, please help
  • Lilliput Touchscreen Connection problems, please help
    Hey everyone..I've been trying to hook up my Lilliput 7" touchscreen to my mini pc, but after installing all the drivers and hooking up all the cables(I believe correctly), still nothing but "no VGA signal"... can anyone help, I've exhausted myself trying all the different possibilities... Thanks in advance!
    BTW, I'm connecting everything using the power from the wall, untill everything is running right and then everything is going into the car. Also, i know the PC is running right because I'm able to run it on a normal monitor.
    Thanks again!
    Please Help!
    I've tried everything, setting it to VGA, setting it to LCD, changing the resolution....
      do you know that the screen is not DOA ?
      have you run the PC with another monitor also ?
