does the lilliput stay on?
  • does the lilliput stay on?
    even after the computer turns off?
    i noticed the LCD stays green (though the screen is blank)
    do i have to manually turn the LCD off?
    i read about the auto-on mod... but what about auto off?
    auto-on mod is the same as auto-off.
    If you haven't done any mod to your screen and you don't turn it off yourself, then the screen is still on unless you cut the power to the screen.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      does it suck up a lot power with it still on and no signal going to the screen? It looks like the screen itself turns off, which leads me to believe that all that's powered is maybe the LED and a few other "behind" the scene things?
        Yes. It will drain your battery.
        http://www.carnetix.com/additional_i...llyCurrent.htm
        I use coyote's auto-power on hack and I am powering my screen directly from the computer's 12V rail.
        http://www.mp3car.com/vbulletin/showthread.php?t=25185
        CarPC status: HW all done, SW needs tweaked.
        Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
        Software: RR, MM/FD
