Rca on Lilliput not working
  • Rca on Lilliput not working
    OK so I try and plug my Xbox into one of my RCA inputs on the lilliput and it says no signal. So when I tried going into the menu on the lilliput and switching the Video so that it says RCAS but when I scroll off that option it resets it and says Video card again. I can't figure out how to make it stay at the RCA input configuration. Is there a trick to entering the option? I'll try any ideas.
    Is there anyway to set up the lilliput so you can view the Bios on it. Everytime I try and view them it says out of range?
    Also the only refresh rate I'm given an option to select is 60Hz and I'm pretty sure I have all the updated drivers because everything else seems to work just fine. Any ideas on that?
    C134, EPIA M10000, 512mb, M1-ATX, DWW-700H, Seagate 40GB, Panasonic DVD/CDRW
    Alpine ERE-180 EQ
    I have searched for it. My Xbox works just fine.
    I really think it's the options on the Lillipt menu. See after I go into the menu on the screen and try to change a setting, it won't stay. When I try and set it to RCA it switches to the card option. I can't get it to stay.
    That's my problem. I also have th enewest driver's from DigitalWW. Is there somewhere else I need to look because I also updated the VGA driver from Epia.
    Any more help would be appreciated
    Alpine ERE-180 EQ
