Double-din is closest to 16:9. Should I go with 8" 16:9? Which?
  • Double-din is closest to 16:9. Should I go with 8" 16:9? Which?
    I'm planning to fit a touchscreen LCD in my car's Double-Din space.
    Dimensions: 7.5"W x 4 3/8"H
    My plan is to remove the LCD's bezel/housing etc, and fit the bare LCD. Even an 8" however would be smaller than the opening, so I might have to bondo/fiberglass or who knows what to cover up and look more factory.
    In any case, these dimensions seem very close to 16:9 screen ratio, and also closer to a 8" diagonal at that.
    I was going to go with a 8" Xenarc TS, but the dimensions of those seems to be 4:3 ratio. Huh?! ANy widescreen 8" Xenarcs? Or other good TS options?
    Thanks!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    7" x 4" is double-din standard...
    You sure it's double-din?
    99bravada.
    Current:
    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
      Well, not 100% sure. I did take those measurements myself though, and they are precise.
      My vehicle is a 2002 Honda CR-V, and has a dd 6-disc CD changer factory. They put a Navi there in European / Japanese models.
      99bravada.
      2002 Honda CR-V
        lilliputs size is 7x4 around the beveld trim u can do a recessed monitor
          Which model?
          Also, I thought I heard consensus that liliis where dimmer?
          2002 Honda CR-V
            the 7 inch lillis... hmm ioono i saw the comparision on digitalww and i like the lilliput better the colors are richer then the xernac stuff they look yellowish compared to the lilli
